Unsullied_Spy
Unsullied_Spy's Avatar
05.12.2009, 09:52 PM
Losi 420 series Road Rash, comes with foam. Losi site doesn't give dimensions though.
http://www.losi.com/Products/Feature...rodId=LOSB7205
Losi 420s will fit 40 series wheels if you don't want to run their 420 wheels (basically a 40 series wheel with a 20mm hex).
Overdriven
Destroyer of Tires
Overdriven's Avatar
05.12.2009, 11:08 PM
I was actually refering to the lack of a diameter measurement, which was important to lincpimp. But you have enlightened me about the different series of wheels. Thanks
YogyBrushless
05.15.2009, 08:08 AM
i have those losi tires mounted on their 420 series wheels they measure right at 6.5" tall, but they need a serious job of balancing (i didnt do it cause i only bash around), hope this helps
Yousef
__________________________________
Must Find Cash For RC
DickyT
05.13.2009, 08:47 AM
60+ mph, 5.75" tall, and just the other day it was extended revo chassis... uh oh linc's gone mad!
nitrostarter
nitrostarter's Avatar
05.13.2009, 09:13 AM
If you'd see the room where all his stuff is, you might think he hasnt gone mad just yet...
N. Rustler conversion
whitrzac
Can't catch this...
whitrzac's Avatar
05.13.2009, 09:42 AM
baja wheels have 23mm hexes, right??
http://www.hpiracing.com/products/en/4837/
Unsullied_Spy
05.13.2009, 09:44 AM
The Baja has 24mm hexes.
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.13.2009, 10:09 AM
Just wondering if anyone has tried reinforced filament tape like this:
http://www.mcmaster.com/#catalog/115/3377/=1utloh
It has fiberglass strands running through it and is almost impossible to tear. I have always had to use a razor blade. I would think it with some of the other tires would offer the properties of a 1:1 steel belted radial. Especially if the tape was applied then backed with a liquid rubber glue type compound. Could probably be used with the 40 series road rage and still kept fairly light.
www.cubicle101.com
05.13.2009, 10:17 AM
I found some 3m clear heavy duty duct tape. It has cloth fibers in it, and worked very well on the badlands. I gave it one wrap with about 1" overlap. This tape has very aggressive adhesive, but is a bit thinner/lighter than std duct tape. As I have beadlocks I tested the benefit with and without the tape. It cut the ballooning way down, maybe only 1/8-1/4" added radius when running after using it, and the truck was geared for the high 40s. Before I used the tape the tires would grow well over 1" to the radius. That and balancing are a must if you plan to run some speed.
TexasSP
TexasSP's Avatar
05.13.2009, 10:23 AM
The reinforced filament tape is definitely thinner and lighter than duct tape. Honestly I doubt you would add hardly any weight and the adhesive is probably aggressive enough to use without the rubber backer. I may try this on the Yusa you sold me when I get it going, someday......
www.cubicle101.com
05.13.2009, 10:24 AM
HAHA, I remember that car. It sat a while before I did anything with it.
TexasSP
TexasSP's Avatar
05.13.2009, 10:32 AM
Same here, the only moving it does is from one spot to another when I need something that is sitting under it. It's a great conversation starter though. Everyone that sees it always asks questions. Maybe I should use it to decorate the coffee table......
my wife would love that!
It's almost like the damn thing doesn't WANT to get built.
www.cubicle101.com
05.15.2009, 01:49 AM
Ok so I have decided to go with a std MT wheels as that wheel type offers the least offset that I can find. So I need a good street tire for a MT wheel. Something close tp 5.75" would be great, and less sidewall bulge would be better too.
nitrostarter
05.15.2009, 07:55 AM
Don't want the 40 series any more?
