tom255
tom255's Avatar
05.19.2009, 04:27 AM
I tried once 3S battery on XT8 wit 2200KV motor and tried to gear it up to stay par with nitros and 5100mAh battery didnt last 10min at all and pack was overheating. So nothing to expect from 3S. Go for 4S and you will be satisfied with with perfomance. Maybe on buggy its OK but for truggy its definatly not enough. If pack can deliver enough amps it will be definatly hotter setup than on 4S.
I think real potencial of RX8 system starts from 4S battery
JThiessen
JThiessen's Avatar
05.19.2009, 08:54 AM
Good report, but I am quite suprised that you chose to run these without at least some bit of "test and tune" - "At least not on a race day with everyone eyeing and curious about the performance of a converted 1/8 in a race setting......."
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.19.2009, 09:44 AM
I would have thought being the combo and all the RX8 would have come kind of pre set for the T8, or maybe it does. I am just thinking out loud here.
Nice report though. Most reports I have seen have not done it back to back same race day and same racers exactly as you had. That's pretty consistent.
This report would some up what my theory is on the two systems. The RX8 has some things better than the MMM and the MMM has some things better to the RX8 without either being vastly superior/inferior to the other.
I would love to try one, but don't see myself spending the extra money on the RX8 when the MMM does everything I need and more.
www.cubicle101.com
superek4
superek4's Avatar
05.19.2009, 09:55 AM
R those temperature in degrees or F?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
Unsullied_Spy
Unsullied_Spy's Avatar
05.19.2009, 10:02 AM
Those are definitely Fahrenheit. That hot in Celcius would be seriously bad!
tedo
Vermont, USA
tedo's Avatar
05.19.2009, 10:20 AM
You have to do the manual or Hotwire tuning. It is not a plug and play system.
However, if you have the Hotwire, everything is programmable on 1 screen. Super, super easy. Then if you needed to do manual track tuning (throttle curves, etc..) the RX8 is pretty easy.
Oh, and timing makes a big difference in performance. I have mine dialed down to 8 degrees. Doesn't hesitate though like Bustafied's... I have the linear throttle curve selected, I just feather the throttle. Takes off instantly.
Bustafied, great race review. Personally, I would get the system worked out ALONE first, haha, before you show up at a race and figure it out in a main.
MBX6T: RX8 2000—sick!!!!
Campbell Buggy Rock Racer on 3S
4x4 Pede
1987 (Gen 1) Lunchbox
glassdoctor
TEAM FUSION
glassdoctor's Avatar
05.19.2009, 10:38 AM
Buddy of mine is running a Tekin system and I've taken a few laps with it too. It runs really smooth and throttle response is crisp... no lag time, etc. He is very happy with it.
I'm running Castle MM/MMM and Neu motors and they are still working good for me. I also have run the MM Pro and it's very nice too.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
05.19.2009, 11:45 AM
Swine!
TexasSP
TexasSP's Avatar
05.19.2009, 12:13 PM
Swine!
Enough said.
www.cubicle101.com
BUSAFIED
05.19.2009, 07:32 PM
Hmm...I've had no problems with my 3S pack. Truth be told, I'm satisfied with the performance on 3S. Then again, I'm running a 2700KV motor compared to the 2200KV you have. That could also be a factor.
Another possibility is that the "C" rating of your 3S pack could be a bit low.
And it could also be that maybe the nitros here are slower compared to the ones you run with.
4S on my truggy is great...but it's overkill for the track.
Just my two cents.
BUSAFIED
05.19.2009, 07:35 PM
Thanks! :)
Yes...I should have looked further into it. Then again, this is my first foray into "sensored" applications. The concepts that I thought would normally apply didn't. Oh well.
Perhaps more adjusting with the TP and timing is in order.
BUSAFIED
05.19.2009, 07:42 PM
Hmm...good thinking. Seems logical to me...makes perfect sense, actually. I dunno why Tekin would leave it out. It could also be that they're (Tekin) letting the racers set their own profile and responses to adjust for each track.
Thanks...and I agree with you. The RX8 does have some points over the MMM, and MMM has it's point over the RX8. The systems are so similar that neither gives up more than a hair to the other. WITH the exception of the cog-free starts in sensored mode. But then again, comparing the two modes wouldn't be an "apples to apples" comparison.
I've tried the RX8, and quite honestly, unless you're a full blown racer with a sponsorship on the line, I think the MMM would suit most needs. It'll definitely work for the club racing stuff...but when we're talking regionals and national qualifiers, the RX8 would be the way to go.
If only they could squeeze more power out of the 2650, though. Then, it'd be golden.
BUSAFIED
05.19.2009, 07:45 PM
ah yes...thank you. :)
I had forgotten about some of the members here who use celsius instead of Farenheit. My apologies.
crazyjr
crazyjr's Avatar
05.19.2009, 08:17 PM
If you're running this in a truggy, you're running the wrong motor. You should be running the 2200kv truggy motor at max, not the 2650 buggy motor. Personally I'd run the 1500-1700 in 4 to 5s before running a 3s setup in a truggy
05.19.2009, 08:20 PM
excellent feedback. I hope you stick around awhile!
