zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.20.2009, 10:53 PM
Is that a brick, or stick pack?
zeropointbug
Z-Pinch racer
05.20.2009, 11:03 PM
nvm, got ya...
zeropointbug
Z-Pinch racer
05.21.2009, 01:01 AM
I finally found that Sticky you were talking about Brian... SuicideNiel did a great job on that one, thumbs up man!
Sammus
Sammus's Avatar
05.21.2009, 03:52 AM
I've tried running A123 cells in e-revo in all kinds of configurations. No go, unless you want to strap them in somehow without using the doors.
Lucariel
Italian Brushless Style
05.21.2009, 06:47 AM
MMM work fine with 8S A123... look here......
http://www.rc-monster.com/forum/showthread.php?t=20899
Brushless Killed the Nitro Star
timaneli
05.21.2009, 12:34 PM
i use 2s 2p a123 in my e-revo and the only thing i done was put some spacers between screws compartment boxes and boxes..
fit good, run great eaven being only 13.2 volts and durable and stable as a rock!!
i don´t exchange mine for lipos......
regards
you are what you race!!
Sammus
Sammus's Avatar
05.21.2009, 05:33 PM
regards
2s2p is 6.6V
05.21.2009, 05:40 PM
He probably meant dual 2s2p, which would be 13.2v...
zeropointbug
Z-Pinch racer
05.21.2009, 06:54 PM
K well what all does a person need then to convert the normal revo 3.3 to BL e-revo? I know I need the chassis, what about the transmission (i want that), battery covers?, receiver box... does Mike carry any of this stuff?
Could I get a little shopping cart list of things I will need, just put in your two cents/knowledge....
"And anyways, you guys think you're smarter than me, and who knows, maybe you are. But what I know is when yer all grown up you gotta do illegal $#@! once in a while and have little bita fun and machurinate into a better person... and you know you're thoughts might be better than mine, but I have thoughts goin around in my head too about different thinkins and brain things you can use and doin different things... so F#$K off, and I think I know whats best for my daughter, and my thoughts and feelings of there own sometimes.... "
zeropointbug
Z-Pinch racer
05.21.2009, 08:42 PM
Ricky!
timaneli
05.22.2009, 06:05 AM
yes. i mean 13.2v at 4600mah.
is more then enough for small or regular tracks.
i run this cells with my hobbywing combo with 2350kv motor geared for 40mph.
is more then enough to smoke nitros if you know what i mean!!
i don´t think for a e-revo is needed more voltage and power then that, maybe more run time for packs!!
i run the car in this setup for 3 months with sucess without any thing break!!
the cells fit the compartments perfectly in size and is 4 cells for each pack wired in paralel and connect in series.
zeropointbug
Z-Pinch racer
05.22.2009, 10:26 PM
mah... 4s2p would be okay i guess, considering it's 2300kv motor (how big BTW?)
I have had my Revo since fall of 2007 I haven't broke anything either... except for suspension arm, my fault.
My Revo running 7s1p and 7s2p packs running 1512 Neu(1700kv) has plenty of power (~1300watts) and agility with the 1p pack... the 7s2p has noticeably more power(2500watts...theoretical) and punch but I don't like the feel of it compared to the 1p pack... too heavy and not as agile.
zeropointbug
Z-Pinch racer
05.27.2009, 08:08 PM
Well I made an 8s A123 pack and it doesn't work with the Quark... I plug it in and turn the switch, it makes an alarm beeping sound (obviously for over-voltage protection)
Well, I think I am going to get either some flightpower EON X30's, or the ThunderPower 40C packs... I am thinking more towards the TP packs however just because of the best voltage holding ability. I am sure they are both good choices.
I just need the E-revo chassis now...
