Freezebyte
05.28.2009, 04:34 PM
Ah ok, perfect. I wonder what are the best bearings I could put in the Tork motor when it comes time to do so?
RUSTED
05.28.2009, 04:42 PM
are the stock bearings on the castle 2650 motor ABEC 1 ???
prhess
RC Addict
05.28.2009, 04:55 PM
Yes they are ABEC 1.
If you can't be good, be bad!
prhess
RC Addict
05.28.2009, 05:10 PM
There were the best I could find
http://www.bocabearings.com/main1.as.../C3_Z/S_#5_AF2 - 99.99 a piece
or
http://www.bocabearings.com/main1.as...=SMR625C-ZZ_#3 - 17.99 a piece
But I went with these due to cost
http://www.bocabearings.com/main1.as...MR625C-YUU_NB2 - 11.99 a piece
RUSTED
05.29.2009, 02:11 AM
i think im gonna order the abec 1 bearing u listed which is the one u got , cause the others say that they r meant to be used in a clean enviroment.
if i get this can i only change the front and keep the rear stock, and i opened the can there are some scratches on the magnet i think from the balls when they flew out of the bearing will it affect anything on the motor
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
05.29.2009, 02:30 AM
On a side note, anyone have trouble keeping the bearing snug inside its socket? When I had to clean out my motor, the rear bearing would easily fall out of its socket and that cannot be good. Any suggestions on what glue to use would be appreciated.
Area 52 Ranch Raceway
T.R.C.R.
big greg
05.29.2009, 02:56 AM
any thread locker will work, i use green loctite at work for 5-12in diameter bearings, works well
Freezebyte
05.29.2009, 12:43 PM
Holy hell, $100 for a bearing? No thanks.
RUSTED
05.29.2009, 12:54 PM
i think the best is the 11.99$ one, because its made for rc motors and its ultra sealed , others require to be ran in relatively clean environment , gonna order it today
nitrostarter
nitrostarter's Avatar
05.29.2009, 01:21 PM
I would send that motor in to castle if the bearing went out already...
N. Rustler conversion
RUSTED
05.29.2009, 02:12 PM
im not sure if ill send it cause sending the motor would cost me more than the bearings , and if it doesnt get accepted for free repair cos i have no receipt i only have the receipt for my of the mmm combo from the lhs , will they accept that ??
