05.30.2009, 12:42 AM
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
05.30.2009, 01:05 AM
IM not saying to ca the thing in place. the epoxy acually fills the gap and when cured should form a nice hex shape, if you dont go overboard on the stuff and cake the whole hex then you will be able to get it out.
to each his own.
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
I am guessing this pic was before Ben got on that "tanning" kick... He looks a bit darker now IIRC!
Patrick
Patrick's Avatar
05.30.2009, 01:53 AM
I epxoyed one of my 17mm rim hexes that was rounded about 3/4 of the way into the wheel (nut came loose and only rounded part of the rim). I put a film of grease on the wheel hex so the epoxy wouldn't stick to it and I could pull it back out of the rim easily.
It worked well for me, but maybe if yours are badly rounded put some grooves in the rim a bit like aqwut did, then the epoxy should have more chance of holding onto the rim. Does JB weld work on plastic? Maybe that is stronger than epoxy.
brushlessboy16
brushlessboy16's Avatar
05.30.2009, 10:11 AM
my last name is White remember?
Thats what i was thinking - does the grease on the hub affect the epoxy?
Would wd-40 work as a release agent?
aqwut
Brushless Heavy Weight....
aqwut's Avatar
05.30.2009, 03:19 PM
can you see what I did. it worked, and been working for a while now...Click image for larger version
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
brushlessboy16
05.30.2009, 03:24 PM
I dont follow.
05.30.2009, 05:05 PM
I dont follow.
if you were looking at the side of the hex, not the face, maybe it would be clearer. If you looked at a wheel mounted on your truggy, you would see the 17mm nuts face.
Now, looking at the side of the hex on the truggy, drill and tap an m3 hole. You would be drilling and tapping the round part, not the flat part. Now make slots on the wheel that an m3 screw will go through and thread into your newly tapped hole on your hex.
something something loose nuts blah blah whatever
Patrick
Patrick's Avatar
05.31.2009, 01:44 AM
I dont follow.
In the second picture you can see the screw head sticking out of the hex and through the slot in the rim.
If you are using wheel hub/hexes that have no extension, you can use a longer pin that holds the hex to the axle (drill bits work if you can't find the right pin). The part of the pin sticking out of the hex goes into the rim to do the same job as the screw aqwut used.
If you are using extended hexes then the pin will miss the rim and you would have to drill into the hex like aqwut.
Even if you slot the rim to put a srew or pin in personally I would still use the epoxy for extra strength.
05.31.2009, 02:43 AM
i've used drill bits, jb weld, two part epoxy. Your best bet is new wheels. You could make it work, but only for so long. Keep your nuts tight and you won't strip a hex. I know you said it was due to cartwheels or backflips or drug muling from el salvador or something but 17mm wheels just don't strip with tight nuts.
bdebde
That's All Folks!
bdebde's Avatar
05.30.2009, 03:37 PM
the moral of this story... don't let your nuts get loose
brushlessboy16
05.30.2009, 03:40 PM
your just waiting for someone to jump on that arent you?
05.30.2009, 04:47 PM
Jump on you nuts? Ouch...
brushlessboy16
05.30.2009, 04:55 PM
not mine, yours.
brushlessboy16
05.30.2009, 05:27 PM
still lost, do i want a hole or slot for the screw to go into?
