Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
01.25.2006, 07:00 PM
How are those mounts above the motor working out for you guys? Helps save space for mounting other things, but what do you sacrifice in strength? Thanks, nice buggy by the way.
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
virusss
virusss's Avatar
01.25.2006, 07:07 PM
sorry i dont understand very well your question(i am italian)if you refer to the aluminum support that goes from the support of the dif centers them to the diff front, servants for to rest the electronics(esc-rice)
Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
01.25.2006, 07:30 PM
Sorry, I meant the vertical motor mount. I thought mounting it above the center differential would make it weaker than to the side.
virusss
virusss's Avatar
Smile 01.25.2006, 07:38 PM
ahhh ok i understand, the motor support made from 6mm high quality aluminium, and there is very very strong,we have chosen to put it over, in order to earn space,and in us it seemed also beautiful. :)
boss 302
01.25.2006, 08:32 PM
Originally Posted by Serum
YEAH!
those flightpowers are THE BOMB!
:p
That thing will be a hand full!! that setup is nice for a heavy weight truck, so it will make that little thing fly.. You contacted Nasa?
it will be the first rc buggy to orbit the earth!!!:eek: :eek: :D
brushless will break another record :p
Dafni
Dafni's Avatar
01.26.2006, 05:49 AM
Here's a pic of my mount, made it for my current project.
virusss
virusss's Avatar
01.26.2006, 07:32 AM
Beautiful support, where you must use?
MetalMan
MetalMan's Avatar
01.26.2006, 10:01 AM
I've found that 1/8" thick vertical motor mounts don't work, but 1/4" (6mm) work just fine. The 1/8" just bend like crazy!
Serum
Serum's Avatar
01.26.2006, 01:19 PM
1/8th would be a nice size for CF, not for aluminum. I use 6mm or 10mm thick aluminum for my mounts. for the lightning i used 5mm, and it needed a brace, to support the XL.
It pretty much depends on the weight of the motor though
virusss
virusss's Avatar
01.26.2006, 01:23 PM
Serum I wanted to ask to you that pinion it uses on the savage, and that spur, I use 18/49
virusss
virusss's Avatar
01.26.2006, 01:24 PM
ah my gearbox is locked in first gear
Dafni
Dafni's Avatar
01.26.2006, 01:45 PM
On this one I used 8mm alu, and the mount will be cross-braced and the rear of the motor gets an adjustable support.
Viruss, it's for a revo.
crazyjr
crazyjr's Avatar
01.26.2006, 07:31 PM
Nice craftsmanship Dafni
Dafni
Dafni's Avatar
01.27.2006, 02:42 AM
Thank you! Stay tuned for the finished truck!
