07.01.2009, 07:40 PM
Wow, I see.
Well, I'm not sure about what cap you are wanting to add.
Do you mean a "glitchbuster" cap to help the BEC cope? If so, that won't work; all it will do is help even the load (smooth out the current spikes). And with tires that big, there is quite a load on the steering servo and BEC. Plain and simple: you need a switching one.
Or, do you mean extra caps on the power lead to augment the existing 3 caps on the ESC? If so, that may help (certainly won't hurt), but I wouldn't expect miracles.
I think your best bet would be to get a UBEC and possibly gear down a tooth or two. A 2700kv motor on 3s is only ~29k rpm, which a bit on the slow side. The ESC may simply be pulling a decent amount of current to retain 35mph speeds. With that motor and tire size, I'd go 4s and gear to 11T or 12T on the pinion. But at 4s, a UBEC is required.
Jason
07.02.2009, 07:06 AM
Yes I talk about a extra cap 1200UF/35V
Jason
07.02.2009, 07:09 AM
what happened if I used heavier diff fluid on the rear diff then the front diff ?
Jason
07.02.2009, 12:43 PM
http://richtechparts.com/i-2564-1200UF_35V.html
do you think these one are low ESR ?
07.02.2009, 12:55 PM
Probably. The 105*C temperature rating is usually low-ESR. The regular style caps are usually rated for 85*C.
Jason
07.02.2009, 06:25 PM
ok good!
Jason
07.04.2009, 07:51 PM
it is possible my 4.72inch tires with the balloning factor goes up to 6inch ? and the speed at 4.72inch are 33.67 mph (54.08 km/h) and with the ballooning the speed goes up to 51.93 mph (83.41 km/h) ...
Metallover
RC-Monster Spudgunner
Metallover's Avatar
07.05.2009, 04:02 PM
Could very well be.
Jason
07.07.2009, 01:23 PM
im back from playing with the crt.5 and I have strapped the GPS the top speed was 39.37 mph (63.25 km/h) the runtime with a 3s 6400mah was 32 minutes I runned 13.2km ( kilometers ) in total.. the outside temp was 13°c ( 55f ) and at the end of the run the motor was 95f and the speed 95f too no body in it and bec disabled ...
Jason
07.07.2009, 02:24 PM
anyone can diagnostic my amps draw from this info ?
and for my rx pack I used 425mah for 32minutes of runtime
so with a bec or not it wont really affect the runtime on the main battery I think ... maybe only around 2 minutes ?
07.07.2009, 02:26 PM
rx 425/32*60=800mah = 0.8amps
Bat = 6400/32 *60= 12 amps
