07.04.2009, 05:01 AM
The tricrimp looks good, I just need the dies to use in my greenlee though, but no one sells just the dies... Guess I am screwed and will have to buy the entire crimper. I plan to add flux to the wire, then crimp it, then feed a little solder in. Only reason I am crimping is a stock 45amp connector will not fit the plastic housing unless you bend the tabs. If I have to bend the tabs I may as well crimp it, right... It will mechanically hold the wire, and the solder can fill the gaps!
