speedracer1129
07.10.2009, 09:07 AM
good luck......
FS: Medusa 80mm 1600kv 5mm
FS: Mega 22/30 3 1270kv 5mm
FS: Datalogger V3 150amp version
nitrostarter
nitrostarter's Avatar
07.10.2009, 09:26 AM
Buy a used motor for that...
N. Rustler conversion
aqwut
Brushless Heavy Weight....
aqwut's Avatar
07.10.2009, 01:05 PM
Originally Posted by iTz Nicholas View Post
When it comes to BL motors "you get what you pay for". I'm always looking for a budget HobbyCity setup but time after time I'm told by others that it's worth it to spend the money on a Medusa/Neu motor.
Yeah, it's true.. I second that.. You do get what you pay for....
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
BrushlessReady
07.10.2009, 01:42 PM
i think it was neil that used this motor in his e maxx build
http://www.bidproduct.com/part/Produ...MOTOR_184.html
emaxxnitro
emaxxnitro's Avatar
07.10.2009, 02:26 PM
Originally Posted by Mentat View Post
what can i get for around $75?
http://www.rc-monster.com/proddetail...WAND_XL&cat=20
808E
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.10.2009, 03:57 PM
If you want a feigao motor, you have to keep them around 30,000rpm for decently reliable performance.
florianz
07.10.2009, 04:52 PM
I would choose a feigao over a bidproduct motor, feigaos have at least a segmented rotor; the wanderer are not that bad, I used to have a small wanderer, had a well balanced rotor (most of the chinese motors are not balanced), good overall quality. the bidproduct ones have great looks, but...
if you want to throw away your money, just go for a kd at HK...
emaxxnitro
emaxxnitro's Avatar
07.10.2009, 05:02 PM
yeah feigaos are balanced and segmented. they are good motors they tend to be on the warm side but the preform well. my back up motor is a feigao and its a good strong motor and they are the best cheap motor.
808E
whitrzac
Can't catch this...
whitrzac's Avatar
07.10.2009, 05:08 PM
talk to linc... he probably has more than a few motors FS
if not, I can part ways with a used 70mm 2000kv medusa
Metallover
RC-Monster Spudgunner
Metallover's Avatar
07.10.2009, 05:27 PM
Used medusa will be your best bet. Then a used CC/Neu.
The CC/Neu motors are cheap alternatives to Neu, so I don't think you'll be anywhere clost to that except for a medusa.
zeropointbug
Z-Pinch racer
07.10.2009, 07:16 PM
Feigao's do not have segmented rotors, they are simply made from multiple set size chunks... XL is three pieces, L cans are two, and S are one piece. IIRC.
A segmented rotor will have small thin magnet 'segments' that make up a larger one... those of you that don't know what it would do; a larger magnet segment will have excess 'eddy currents' caused by high frequency switching (from ESC, both the carrier frequency: PWM, and the pole switching)... now when you reduce the size of these pieces, you reduce the eddy currents, thus less heat is created. A 'sintered' rotor is the best for this as the 'segments' are very small, particles really... so you can see how this would create the least amount of heat created by eddy currents.
Mentat
Brushless Mentat
Mentat's Avatar
07.10.2009, 08:32 PM
what about winding your own motor? is that a difficult task? Anyone here do it or done it?
FS: 8ight-t Race Roller TONS of UPGRADES
8ight 1.0 & 2.0 | 8ight-T 1.0 & 2.0 | E-Revo BL Edition | T-Maxx | Slash | Raze-ST | XXX-NT Drake | 3PKS | DX3S Telemetry
zeropointbug
Z-Pinch racer
07.10.2009, 08:43 PM
You can wind your own outrunner type motor, much easier. An inrunner is a different story, you need special tools/jigs to do a proper job...
