08.03.2009, 07:04 PM
It's all good, and I figured BrianG would add it^ I did kind of speak for everybody, sorry. (God complex) But you sound very knowledgeable and its always good to see newer members. Happy r/c'ing!
simplechamp
simplechamp's Avatar
08.03.2009, 07:10 PM
It's nice to be able to debate a subject with someone with out it turning into "u r teh lame idi0t go to h3ll!1!1!!" like it often times does in online forums!
08.03.2009, 10:51 PM
That's why this is the only forum I'm on (except nudecelebforum)
redshift
RC-Monster Square Tube
redshift's Avatar
08.03.2009, 11:16 PM
Sounds like a real wellspring of knowledge there H... is that even real? (no I'm not checking, but I'm sure the kids will)
And champ.. some of these guys are impossible to please.......
08.04.2009, 01:24 AM
it's real! I'm _paralyzed_ there as well!
08.03.2009, 07:42 PM
FYI, the update has been uploaded. Let me know if it is confusing or anything...
simplechamp
08.03.2009, 11:02 PM
Did you consider listing the actual rollout value in the results with all the other calculated values? Then as you played around with different variables you could see how it affected your rollout. And you could still use the gearing table to find what would put you at 1:1
The two values are already there, so I suppose anyone who wanted to could divide it themselves (what I have been doing) but it would save that extra step.
dkexige
08.03.2009, 11:49 PM
Just wanted to take the opportunity to thank Brian for the speed calculator. Its probably saved all of us hours of number crunching! The hidden warnings about the 45mph is a good and welcome idea.
Since you're including the calculation for the recommended pinion for 1:1 rollout ratio, maybe it would be a good idea to include the little bit about (tire circumference) / (gear reduction ratio) in either the discriptions or a displayed calculation?
.dk
