08.11.2009, 07:36 PM
i havent had any problems with any of the savage diffs... both with 18 nimh cell and 4S lipo use, with stock savage 21, flux and upgraded alloy 4bevel gear diffs also... All diffs are shimmed well
probably around 146 runs on all of the combos combined.
-lol- sorry - couldn't help it hehehe
n00b
08.12.2009, 09:30 AM
LOL, when I was reading that '146' I was like omg, should I also start counting my runs or what :D.
Anyways, seems my diffs are still fine, just broken my front bevel gear.
@ JTiessen, I, and many others, 'solved' it by putting a tyrip around it (not to thight because otherwise it will snap), haven't had a problem since. I know TCSCrawler had a brace made for this 'problem'. Altough after some bashing and testing he found out that the brace wasn't strong enough.
EDIT : @ Finnster (below) : Sorry, I meant the same as you. The zip ties just stop them from rotating.
Mugen MBX6Te RCM + Mugen MBX6e RCM + Savage Flux XL FLM + MERV all with Spectrum DX3S || WTS& WTB
roofles.
08.12.2009, 12:28 PM
I wonder if they're going to do anything with the eSavage, probably not..
Damnit...
08.12.2009, 12:56 PM
Rawbuns- do you have to have damnit in every post?
Sorry for the threadjack guys...
08.12.2009, 01:32 PM
Damnit...
Hmmm - but they did. Unfortunatley, you can only buy it in a complete 650 dollar package, or in parts on ebay.
roofles.
08.12.2009, 01:05 PM
When HPI doesn't upgrade a thing on the eSavage, yes
So damnit!
roofles.
08.12.2009, 01:35 PM
 Besides the Flux, as in upgrades to the drivetrain in any way!
08.14.2009, 03:55 PM
kershaw designs has a eSavage tranny. it is based off of their electric conversion tranny for the nitro savages. it is better and lighter than the flux transmission.
roofles.
08.14.2009, 04:17 PM
My tranny is still very nice, but I'd rather have better diffs, other than the GCM Twin Diffs, which cost me an arm and a leg.
08.17.2009, 03:13 PM
I'm running 6s with the punch control set to 100% and reduced the throttle curve. I've broken 5 rear diff pinions. I made sure they were shimmed properly each time I replaced it.
I now have the CEN diffs in there. I took it out for the first time a couple weeks ago and somehow managed to crack the rear bulkhead where the pinion comes out. I wasn't even driving it hard. The rear pinion completely tore through the bulkhead. Both gears were fine when I took it apart.
I got the bulkhead replaced and figured the damage was a fluke. Last Saturday, It was holding up great. I was driving fairly recklessly doing backflips off of jumps and had some bad landings that would've broke the stock pinion right away. At the end of the day, I did a standing backflip off a curb and heard something crack. After it landed, I heard the click from the rear diff. I'm pretty sure the pinion lost a tooth. I saw exactly what happened though. When I did the backflip, I saw the rear wheels hit the curb and that's when I heard the crack. I haven't torn it apart it to see the damage, but chances are the pinion broke a tooth.
Everytime I broke a stock one, It was from doing a backflip and landed hard. I always let off the throttle when i'm doing the backflips, but maybe i'm not letting off early enough.
The CEN gears seem to be significantly stronger, but not quite "bullet proof" yet. Then again, I am driving it harder than I probably should.
Hopefully HPI's new diff will be much better.
08.17.2009, 05:15 PM
Originally Posted by Trike
Everytime I broke a stock one, It was from doing a backflip and landed hard. I always let off the throttle when i'm doing the backflips, but maybe i'm not letting off early enough............................................ Then again, I am driving it harder than I probably should....................
A good example of why warranties have small print!!!!
Glad you are having fun with it!
High-Voltage Fetish
09.15.2009, 10:19 PM
This thread is a bit old, but you asked me a question and I don't think anyone else answered it. I am using the NITRO savage pinion gear, with the stock flux bevel gear. I added a shim to the pinion, and it works awesome for me. Like I have said, I have done probably hundreds of backflips now (it entertains buddies lol) and since I changed a few things, no broken diffs.
09.19.2009, 09:52 AM
Amen to that brother, In the last year I have EXPLODED a total of 44 spider gears in my FLM savage!! NO this is not a exaderation(11times x 4gears).
Everything is shimmed and built correctly. The truck weighs 18.5 pounds and has a NEU 1521 2d motor on six cells so torque is incredible. Have not tried the CEN diffs yet but the Flux mod does not help. Have been working with Jamie from FLM to try and fix the problem and no luck.
So I hope to god they have this fixed.
FLM Extended Savage -Nue 1521 2d MMMv3 6cell
E-Maxx -Flm Parts stock motors (the wife's)
Slash -MM medusa 3300k 3cell 68 mph!
[B]Custom FLM Axial Crawler
Losi Rammunition 1/184600k
09.21.2009, 06:35 PM
I am working with Jamie at FLM in getting a CEN/HPI/FLM upgrade for the savage/flux. If it works out right you should be a truly bullet proof complete diff that ready to drop in and needs no shimming. Will keep you up to date. Am meeting with him again tomorrow.
09.21.2009, 10:30 PM
Geez....now ya tell me.
