maxair45
maxair45's Avatar
08.07.2009, 12:48 AM
wait for the MMPro to be available.
God I am counting down the days and saving the $$$.
I used to run a MM esc in an old conversion. I did like what was mentioned before run a computer fan to the side of it. Didn't temp. it but it did the job. It still runs I believe(sold it to a buddy.
rawfuls
roofles.
rawfuls's Avatar
08.07.2009, 12:55 AM
I was thinking about the MMPro.. but I already have the MM, why not put it to good use? :)
rawfuls
roofles.
rawfuls's Avatar
08.07.2009, 02:21 AM
BrianG, or any electronic wizard, or anyone who knows what kind of capacitor I need, can I use Mike's from RCM's store?
These?
http://www.rc-monster.com/brushlesscontrollers.php?pg=4
Or could I go with the 2700uF and get better ratings, or could I go higher uF's, and get lower temps, I'm so lost right now..
08.07.2009, 09:35 AM
Thing I worry about is your poor esav drivetrain. I don't think it'll like a beast of a motor spinning at almost 49k rpm...
08.07.2009, 10:48 AM
These?
It is better to use several smaller uF caps in parallel, rather than one large cap- better heat dissipation and responce time to voltage spikes.
That said, a total uF value of about ~5000 shouldnt be exceded, lest you poop yourself at the giant sparks that also eat away at your battery & esc plugs...
Solder them in parallel to the esc's battery wires, + leg of the cap to + wire, and - to -, close to the esc as possible (strip some insulation away with an exacto blade etc).
rawfuls
roofles.
rawfuls's Avatar
08.07.2009, 10:58 AM
You've lost me, as I'm an idiot, how many and what uF caps would you recommend?
And a diagram of the drawing? Sorry, I'm a retard..
As far as the ESav's drivetrain, I was thinking about switching the ESav arms for the Sav X arms, as well as the dogbones, this will be a time consuming project, about a couple hours, with money I don't have.....yet
Thanks guys for the help so far!
08.07.2009, 11:18 AM
The single hvmaxx type cap would work fine, but a couple of those ones mike sells (in your link) would be better.
Im at work so cant do a diagram, and havent got any of my IE favourites to reference, but hopefully someone will help you with that or a photo.
nitrostarter
nitrostarter's Avatar
08.07.2009, 11:20 AM
Neil: love the new avatar. It looks like something from the movie "Watchmen"
N. Rustler conversion
rawfuls
roofles.
rawfuls's Avatar
08.07.2009, 11:49 AM
I will try out the one or multiple, once I get a diagram :)
08.07.2009, 12:10 PM
MS Paint to the rescue.
If you had two caps, you'd just twist the + legs together then solder to the power wire, same deal with the - legs. You will ofcourse have to insulate any bare wire or cap leads to prevent a short; keep any fly leads short as possible and mount the cap to the esc case with some doubled sided sticky pads etc.
rawfuls
roofles.
rawfuls's Avatar
08.07.2009, 12:11 PM
I love you Neil, thanks.
I'm assuming the longer leg is positive?
08.07.2009, 02:31 PM
I love you Neil
Awkward...
nitrostarter
08.07.2009, 02:45 PM
Man love! lol... still awkward!
rawfuls
roofles.
rawfuls's Avatar
08.07.2009, 02:50 PM
You guys would do that
nitrostarter
08.07.2009, 03:05 PM
You said it, not me...
