cabking
02.19.2006, 05:18 AM
Ive got the Pro peak 20amp supply, great value for money
Ive had 3 chargers hanging on it charging a total of 36 cells @ 4amps at the same time.
HotnCold
HotnCold's Avatar
02.19.2006, 08:49 AM
Originally Posted by JOHNNYMAXXIMA
Are you saying that you had 3 battery chargers hooked up to this one power supply at the same time?
Thanks.
Yep - 2 turbo 35 chargers - one charging @ 5.5A, another one charging @ 6.0A, and my astroflight charging my Lipos..
Hows that "Hope and Change" working out for Ya???
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
02.20.2006, 01:06 AM
You got any pics HotnCold of all those chargers connected to that power supply? Do you need any additional cords or wires for this connection?
Thanks.
crazyjr
crazyjr's Avatar
02.18.2006, 08:37 PM
Originally Posted by E-maxx-kid
I have this power supply and have found it very good.
http://www.hobbypeople.net/gallery/158301.asp
thanks, i was going to ask about it
Scott711
Scott711's Avatar
02.18.2006, 10:11 PM
I went with a complete Hyperion set up for batts, charger and balancer. I can't compare them to anything else since I'm just getting into lipo but the use and performance has been great, everything I expected and more. I also like the simplicity of the whole setup. It gives me alot of confidence in what I'm doing, a real safe feeling. I would also recommend getting a ceramic pet food dish or something fire proof to set your batteries in while charging and if you have one keep a fire extinguisher close by or a small bucket of sand will work. Enjoy. :027:
Batteries
Charger & balancer
cabking
02.20.2006, 05:34 AM
I use banana plugs with the socket on the pack, so you can plug them together.
I have seen a set up with 2x 10mm studs in a block of wood wired up to the + and _. then you can use crock clips to clip to the studs.....................if that makes sense?
JOHNNYMAXXIMA
02.21.2006, 03:08 AM
Any pics?
HotnCold
HotnCold's Avatar
02.21.2006, 07:53 AM
No pics - But i can describe how I did id Johnymaxima - In the back of the charger where you make your positive and negative connections - i used the largest wire i could - made it about an inch and a half - on both sides - and then soldered 3 smaller guage wires to the positive wire and 3 smaller gauge wires to the negative wire - which i soldered my deans connectors to. Then on each charger - for the power leads i soldered deans connectors onto each of the chargers and plug them in as needed - I can have one two or three plugged in at a time. Really quite simple - not the prettiest if you were to look at the back of the power supply - but function beats form for me in this matter.
Superemaxx89
02.21.2006, 11:58 PM
I hate to be the bearer of bad news, but:
Two 5s packs, while though they will power your truck, if wired in series the cells longetivity is at stake. Though you will have an LVP, what if the voltage per cell within the pack varies? The whole pack becomes usless b/c of one cell. Now if the 5s packs were wired parallel, if one cells charge voltage goes down inproportionate to the others, the other cells will proportionatly charge the cell to nominal level. In a nutshell, to power your sytem you should buy one motor (probably like a 12-14xl...why do you want to run two motors anyway?), one esc, save money (by only buying one system) and then buy--i know this may sound crazy-- two 10s packs and wire them parallel.
This is the only way to make sure your lipo don't undercharge and ruin themselves. An LVP is solving only 25% of your undercharging problems.
This is just an option though, the risk is yours to take.
MetalMan
MetalMan's Avatar
02.22.2006, 12:13 AM
If 1 of 2 5s packs in parallel had a cell that went south, then the other pack's voltage would be forced to drop also, perhaps into the unsafe region. The way I see it, the best thing to do is get packs that are built in a parallel fashion so that if any cells go down they will only take their "mates" (cells in parallel with them) down instead of a whole pack that's in parallel. So, instead of 2 10s packs in parallel, 2 5s2p packs in series would be a better option. This also makes charging easier because each group of cells in parallel (2p) will maintain voltage amongst themselves that can be monitored via a single set of taps (so 10 cells to tap total), whereas with 2 10s packs in parallel you have 20 cells to have taps on.
If one cell in a pack went bad (dropped its voltage), then the LVC may be hit, which would stop you from running with the bad cell, creating less potential damage to an already damaged cell.
JOHNNYMAXXIMA
02.22.2006, 06:46 AM
Superemaxx89-
I've been running dual 9L's for a while now. I run the dual's mainly just because I can. My truck is more of a "show truck" and only gets run in the street and occasionaly on the grass. I have another single BL Maxx that I use for bashing.
The dual's are run seperate of eachother, each with their own speed control and own set of batteries. So correct me if I'm wrong (which is highly probable as I am still new to this r/c stuff) if I am running my setup as described above, the 2 LiPo packs (one 5s per motor and speed controler) have nothing to do with eachother? Forgive me if this is not what you were talking about, because 99% of what you said was way beyond me.:002: :005:
I do however like your idea for a setup (12-14XL on two 10s packs) for my single BL Maxx!
