simplechamp
simplechamp's Avatar
09.22.2009, 02:41 AM
OK, so yeah it's got two male Dean's plugs in series. So all you would need to get is a female Dean's plug and a small piece of 10G or 12G wire. Solder the wire across the two tabs on the female Dean's (use a little bit of heatshrink to ensure there is no exposed metal). Then you plug your newly made jumper into one of the male plugs on the ESC and plug your battery into the other one. All set to use a single battery, and if you decide to use two batteries you just remove the jumper.
bernyberns
09.22.2009, 03:03 AM
hold up hold up its a way i can still use two batteries later?? can u please go into detail for me about this i would appreciate it
simplechamp
09.22.2009, 04:44 AM
Look at my drawing in the previous post. You won't change anything about the ESC, you are just making a little jumper plug to fill one of the male Dean's in the ESC.
