What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
10.01.2009, 12:25 PM
Originally Posted by TexasSP View Post
Looks nice so far. What are you going to do as far as motor supports?
Originally Posted by sujuara View Post
And with the motor mount... i think the 6mm thick L bracket would be kul enough to handle the motor... 1 side of L brac... will be mounted directly to the chassis,..and the other side will be mounted together with the clutch holder and side chassis.... and finally with the other end of motor.... i think im gonna use 2...3.. of 6mm thick acrylic..to hold up the motor... that be kul...
10.01.2009, 01:15 PM
Beat me to it
sujuara
10.02.2009, 08:37 AM
just wait n see
sujuara
10.25.2009, 06:59 AM
Almost complete:
Motor mounted:
IMG_1895
IMG_1897
IMG_1898
Hobbywing EZrun 150
IMG_1904
IMG_1905
6mm bullet connector
IMG_1907
IMG_1908
ESC mounted
IMG_1911
I got 1 video..uploading by now... not lucky as A123 pack almost flat... will have power pack charging 2mrow... and try to have test run on 6S first
sujuara
10.25.2009, 07:51 AM
video uploaded
10.25.2009, 10:23 AM
Damn, I'll have to watch the video when I get home, work PC is a piece of shite and wont play flash videos.
Looking awesome though, but Im a bit dubious about the hobbywing esc- let us know how it performs for you
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
10.25.2009, 02:54 PM
I didn't know you were going to use a Hobbywing esc... can't see it lasting too long. I would contact Lutach and get his HV esc, should do a much better job at throwing that car around.
BTW, as far as the power calcs go, each cell can do 2.8v/cell @ 70 amps typically. So whatever size pack you are using, use those specs as a base line when calculating how many cells you want to use.
10.25.2009, 06:31 PM
Just to be redundant- that HW ESC isn't going to do well at all. Maybe give the new turnigy monster-2000 a try? That would work oh-so nicely.
http://hobbycity.com/hobbycity/store..._Brushless_ESC
lutach
lutach's Avatar
10.25.2009, 07:17 PM
If it has the same throttle and brake response as the car ESC the manufacturer sent me, he will be one pissed of person.
sujuara
10.26.2009, 03:46 AM
Hey guys... dont be so ... **?/...
My mate got his Serpent 960 converted to brushless... he used other 240A ESc..(which cost him 400 buck)..and get his brushless 960 up to 104kph....
with the same set up... but dif. ESc.. (this time Hobbywing EZrun 150A)....his car now up to 134kph... brake..perfectly...
But anyway.... first i will try with this HW ESC and 6s A123... next It will be with 12S A123 n 12S aircraft ESc... and then with 6s Lipo and 10S lipo...for sure...will keep u guys posted
10.26.2009, 10:42 AM
We're not being cocks deliberately, just being cautious about the esc- it works great when it works, but the failure rate is higher compared to the MMM from what I've seen.
sujuara
10.30.2009, 09:04 PM
conversion completed.... hope it's not raining this weekend... im not worried about ESC brake failure.. coz im gonna use car own brake... as later on im gonna run that with 12S power pack and 12S aircraft ESC... and 12s ESC doesnt have brake.... car mech brake...always my 1st choice...
sujuara
11.01.2009, 03:53 AM
Car up to 67kph max with fully charged A123 - 6S...
Ryu James
Ryu James's Avatar
11.01.2009, 08:33 PM
Good looking project there. what do you think of the 2wd? i had a 1/5 Smartech 2wd on rd i just started to tear down to convert last week but i ended up selling it on ebay just 2 days ago. i decided to wait and do a different conversion with 4wd.
your build looks clean though. great work. keep us posted on performance specs as you add/change betteries and esc. 67kph isnt very fast for a brushless 1/5 on road. i would think about 105kph (=65mph) would be ideal. i am sure you wont have a problem hitting that speed with the right batteries and esc setup. keep it up.
Jammin SCRT10 Neu 1512 1y
11.01.2009, 11:57 PM
I want one, it looks so fun to drive on tarmac; doesnt want to do barrel rolls when you pitch it into a turn like my Gmaxx does...
