10.19.2009, 08:27 PM
Subscribed. Looks like a cool project. Should do rather nicely in the snow.
schofield
schofield's Avatar
10.21.2009, 08:57 AM
a little update:
i decided to just go ahead and make it.
i used a t-maxx bulkhead half, lower arm and shock tower.
here are the parts cut out:
together:
close up on chassis:
and mock up on car:
kEEp It sUrrEAl
10.21.2009, 08:24 PM
Interesting, eager to see how that susp setup will work.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
10.21.2009, 09:20 PM
I like it! I hope it performs as well as it looks. Do you plan on jumping? If so you will want the stiffest springs possible on those center shocks and probably 80+ weight shock oil.
update pics
schofield
schofield's Avatar
update pics - 10.22.2009, 09:06 AM
update:
after about 10 hrs of dremeling my work desk was a mess, but i had everything cut out:
time to clean up and take part count:
the parts are getting fewer and fewer:
i made a jig to keep parts straight, i CA glued them first in place to make sure they work, then drilled and screwed them in place.
here is her stance, with out anything like motors/batteries or servos on it. once everything is put on im hoping the stance will flatten out. then when in the air the rear will move down (like a snowmobile). i will use a bandit body in the end, but for now, an old school hornet body from the mid 80's. the shocks still need to be cleaned/resealed and find the right springs/oil - these are just for mock up now.
kEEp It sUrrEAl
What's_nitro?
10.22.2009, 05:49 PM
Nice work. You can always throw a few pre-load spacers on the shocks if it flattens out too much.
10.22.2009, 06:07 PM
Kind of a dumb question, but is a rear suspension even needed? I can maybe see the need if racing on hard packed snow or ice, and/or plan on doing jumping. Dunno, just thinking out loud here.
BP-Revo
BMW M Power!
BP-Revo's Avatar
10.22.2009, 08:48 PM
I would make the center suspension really stiff and make each wheel rather light but limit the travel. So under normal driving the individual suspension soaks up all the bumps but on a larger jump that uses more travel, the stiffer springs will keep you from bottoming out.
Very cool original idea. Keep it up.
simplechamp
simplechamp's Avatar
10.22.2009, 11:32 PM
Is ANYTHING you speed maniacs do around here necessary? I agree that simpler is often better, but sometimes it's all about going above and beyond what is practical just for the fun of it, and seeing what will happen.
Similar to the concept of dual-rate springs, but separating the hard rate and soft rate into the two separate sections of the suspension. I think it's a cool idea too. Can't wait to see how it works!
schofield
schofield's Avatar
10.23.2009, 09:15 AM
probably not but im going for a snow only vehicle that will move down in the snow on bumps and holes. kind of like a snowmobile (or from what i have seen and researched).
here she is almost done, just need to rebuild shocks and install my VXL. the Vxl is in another vehicle till it snows. i am going to have to wait a while. I have had the lipo for a while but have never ran it, this will be my first taste of lipo.
I looked at snowmobile suspension and found what i had laying around that matched it somewhat. Turned out to be a t-maxx bulk head half, arm and shock tower. all angles are correct as they are used on the t-maxx, so i didn't have to worry about making the shock at some weird angle.
still need a bandit body (have to wait till they come in stock from tower (new version))
kEEp It sUrrEAl
simplechamp
10.23.2009, 01:48 PM
I like the snow plow you got on the front!
schofield
schofield's Avatar
10.23.2009, 02:10 PM
its from a roller blade knee pad, cut down. i was going for a boat hull front, sorta.
kEEp It sUrrEAl
What's_nitro?
10.23.2009, 07:16 PM
I have a feeling you might need to get the Maxx paddles for it if you get a lot of soft snow. Maybe you should anyways... they have a much wider/deeper tread.
Unsullied_Spy
Unsullied_Spy's Avatar
10.23.2009, 07:44 PM
Great project! Those Sand Paws are good for ~1 inch of snow, maybe 2 inches if it's not too soft but much more than that and they aren't much good. Later in the year when it gets cold and the snow crusts over they are AWESOME!
schofield
schofield's Avatar
10.26.2009, 12:03 PM
i have thought about it, but i have run these tires on a slash all last winter and they did everything i wanted them to do. expect flex down to get the holes and ditches. but yes i will keep this in mind, also this is a scrap pieces build. only bought parts are the waterproof rustler radio box and a set of jato arms. the body will be new as well, but still deciding on the easy way of waterproofing with a bandit body or go fun and get to use the heat gun and get a Hornet body. My wife will not give me an RC allowance so i if i want to make something it has to be from the scrap pile.
with the maxx size tires i would need some driveline upgrades and with out any money to spend, it's never gonna happen.
i am limited by my parts, but my imagination says go big and fast and pick up the pieces later.
kEEp It sUrrEAl
