Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
03.02.2010, 10:40 PM
Originally Posted by nativepaul View Post
Carbon discs with no pads.
Can you recommend a place? Think they'll hold up to braking from 120mph? Up to 150 (speed I'm shooting for)?
Originally Posted by JVille View Post
Those are GRP tires. I have been using those always in my GT and plan to continue using those as it is cheap nowadays. Half the price from grp store compared to that what they were when I bought those. I have been using soft (B) but those take quite a long time to warm up so I think I will buy ExtraSoft (A) next.
I have been using fibreglass disks with no pads. The disks I have used are stock disks from X1-CR-FT, X1-CRT-X1-CRT-RTR. Hong Nor spare part number is XT-16, don't know if the Jammin part number is the same. The mount is the same so no further modifications required.
I also used these pads and also on the front and rear center dogbone when using the 2-speed. It is also possible to use brake in front and rear on GT, it just requires long screws and as the rear brake goes too far away use old calibers and pads or something similar as a spacer.
I really like the brake force of fibreglass disks. You could even use these nicely enough with the stock Perfex transmitter. Brake force is better than with the stock pads but as there is no pads and fibreglass it allows a bit of skidding, so there is just a small amount of wheel locking if not at all. Most of drivers I know who are using the Kyosho acre pads, also use the ABS function. Which might not be good considering servo lifetime. Brake force with acre pads is awesome.
It would be nice to see a photo of burnt disk. I have also had earlier a Pureten Alpha which also had a plastic brake disk. I don't know what idea it is to use a plastic disk.
Ville
Are you sure the GRPs are made still? I thought they were discontinued? Last time I checked they weren't on Losi's site or Horizon. Eventually I hope to have this car over 150 so I'm not sure if running off straight disks will hold. Thoughts? And thanks for the info on pads.
BTW...did you guys see this? New 2 speed tranny for the GT2. http://kyoshoamerica.com/news.php?article_id=240
Joe Ford
Product Specialist
snellemin
2 KiloWatt RACER
snellemin's Avatar
03.03.2010, 10:31 AM
You can still get them from www.grpgandini.com.
look under buggy tires.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
Joe Ford
Joe Ford's Avatar
03.03.2010, 08:22 PM
Ah, gotcha...Losi and Horizon just stopped distributing them. Thanks for the heads up.
Joe Ford
Product Specialist
JVille
03.04.2010, 04:04 PM
Nice clean setup. Any shots with the body on?
No I'm sorry but don't have any shots with the body on. And I won't take before I buy a new body. It just doesn't look good when there is brushless conversion car with the body that has all the dirt made by nitro engine and the extra cooling holes made for the engine also.
Probably the reason why Losi and Horizon stopped distributing those was this. I don't have any facts but I think so.
JVille
ebomb
03.23.2010, 11:45 PM
i was just curious what everybody is run for diff fluid, and if there are any setups out there, thanks
JVille
03.24.2010, 10:42 AM
I have 30000 in center diff as Kyosho suggested in their conversion guide http://www.kyoshoamerica.com/IFW451_Howto.html Then I have also 30000 in the front and 7000 in back.
Ville
ebomb
03.24.2010, 10:09 PM
well ran it today with 30,000 up front and in the rear turned much better,but i also installed my mmm 2650 and was running on 3s with 16t pinion,im sure tis would be a decent track setup to start with
nativepaul
nativepaul's Avatar
03.25.2010, 11:39 AM
Xtreme Racing make them for the mp777, I'm not 100% but guess they would fit the IGT2, or theres the time consuming but economical option of taking a Dremel to a sheet of CF.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
MiamiJato
04.12.2010, 09:37 AM
yeah, the tirers from grp are way cheaper them what the hobby shops used to sell them for...
Castle MMM and 2200
Big House
Big House's Avatar
Castle MMM and 2200 - 04.12.2010, 08:40 PM
Just my 2 cents. I am running Castle MMM 2200 combo in my GTP and it is a beast on 5s. I don't even want imagine 6s but I will soon enough. Even on foams I get no traction. It is fun to drift though.
DCastaneda
Speed Addict
DCastaneda's Avatar
04.12.2010, 10:35 PM
Yep 44 shipped from Italia Alex I got something new in the works buddy (probably along the same lines as what Joe Ford is doing)
  Send a message via AIM to DCastaneda
