Unsullied_Spy
Unsullied_Spy's Avatar
12.04.2009, 02:00 PM
Originally Posted by Drifted Demon View Post
Guys, i think i may have the same problem. Just got a balancer today, chucked it on & wouldnt balance. I will remove the heatshrink on the end, but what can i use to reseal the end over, i dont have big/wide enough heatshrink. I really want to get this thing balanced so i can use it for sundays racing....
I'd just take the heatshrink off at the end and there is a thin plastic piece that covers the end, take that off as well. From there you can inspect the soldering without completely taking off all the shrink wrap. I need to buy new shrink wrap for mine because I took it all off, but you should be able to remove just the section coving the solder tabs and PCB.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.04.2009, 09:53 AM
Check the voltage in each cell with a meter, if all cells are good(they'll probably be at around 3.85 volts per) then it could very well be the balance tab itself. I've had to replace many balance plugs due to a failure. If this is the case it's a cheap easy fix (2.00) requireing a new plug and soldering.
Drifted Demon
12.05.2009, 06:46 AM
nvrmind guys found the problem. cell 1 was 1.70V & cell 2 was 4.48V!! Im charging the cells individually, then balance them....
