Serum
Serum's Avatar
02.27.2006, 08:12 PM
according to the datasheet it is limited to 70A, due to the TO220 package. (even at 25 degree celcius)
on 75 degree, the max current would be 175A, though it is limited to 70A by the housing.
GriffinRU
02.27.2006, 08:30 PM
Thats true if you are on safe side...
There are some other limits as well, but at 300+A continious motor will meltdown :)
Key element is to keep FET's at 70-80C and the rest would be good.
But we are pushing limits here, right?
Even 70A*2*1.73 good current.
Artur
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
02.27.2006, 08:46 PM
Neat idea, Artur. Very interesting indeed. :)
GriffinRU
02.27.2006, 08:58 PM
Thanks, Mike
I will keep updating on testing.
My camera will be back on Thursday, so I will add some pictures and know-how about setup. It is pretty strait forward but timing can be tricky.
Artur
P.S. How 66 spur with 18 pinion sounds with HV4400 and 7XL ...
crazyjr
crazyjr's Avatar
Originally Posted by GriffinRU
7XL runs on HV4400 controller, HV4400 motor runs free. I am using only sensors from Novak's motor to drive big motor.
Artur
thats what i was thinking, but its so out of the box, i didn't think to say it that way.:027: pretty cool idea. The only problem i see with the fegaio sensored is that the sensor plug won't be the same
RC-Monster Mike
Site Owner
02.27.2006, 09:29 PM
Stock gearing is fine for the 7xl, Artur. I imagine the timing would be the tricky part. I look forward to your continued info on this little project.
boss 302
02.27.2006, 10:32 PM
your project definately has potential to be a great way to drive at low speeds and not have to worry about cogging.
GriffinRU
02.27.2006, 11:41 PM
Well, we can solve this with adapter.
Pulling stumps along the way...
It is spinning at high revs as well. Now, even small motors can pull nicely. I tried C50 14.4 in place of 7XL and it was very nice. I might consider C50 as a better match, 3 broken tranny gears and 2 melted spurs, too much damage. But I will keep updates on both.
Artur
MetalMan
MetalMan's Avatar
02.27.2006, 11:55 PM
This is a very interesting idea! A perfectly smooth sensorless motor... Who would have thought!?!? Besides the requirement of two motors, I'd be more than willing to test this out! It would be nice if Feigao brought out some sensorless motors compatible (in stock form) with the HV ESC!
Dafni
Dafni's Avatar
02.28.2006, 02:58 AM
Very nice, Artur, very nice indeed!
I have never had a Novak, but would it be possible to open it up and isolate the sensor part? Or maybe at least get rid of the heavy magnet? Reducing rotating mass is always good.
As for your broken tranny gears, I assume you keep shredding idlers, right? If yes, just replace it with mikes steel idlers and you will not have to worry about your tranny anymore. And a strobe slipper says goodbye to molten spurs, too.
You definitely can get the driveline up to the job with some minor investments.
On a 7XL you can also try 18/66 gearing. On my revo (and 14 cells) 18/66 gave me lower temps than the 16/66. Just a heads up.
Just for the record, even on "just" a Warrior the low speed characteristics are very good. Especially on the high-end Lehners, for which the BK controllers were designed, you get a very smooth low speed. I use to crawl over rock piles with my LT revo and a 1950, with adequate gearing.
But your idea is nice, nevertheless. Keep us updated.
Cheers
DAF
Sneeck
RC-Monster Custom
Sneeck's Avatar
02.28.2006, 08:47 AM
Don't forget about those little metal pin's that hold the metal pinion's on on the input shaft. They will shear off at some point. Nail solves that problem.
Very cool idea. Like to get a video of this in action.
crazyjr
crazyjr's Avatar
02.28.2006, 09:39 AM
Hey GriffinRU, I just had a thought allong the lines you are working. You could substitute a smaller Novak in place of the 4400 motor and save some weight? Also could eliminate the magnet and save even more weight, may give you more snap as well from the lower rotating mass. Even further along those lines you could eliminate the windings, because you are not using them and take out even more weight if you wanted to, i think.
Sneeck
RC-Monster Custom
Sneeck's Avatar
02.28.2006, 10:55 AM
No you need the magnet and windings in order for the sensor to work. Remember that the sensor "read's" in what position the rotor is in and by this can give power to the desired winding in order to work correctly. By eliminating either the spool or winding's I doubt that the controller will power the motor since it need's the sensor to work.
Serum
Serum's Avatar
02.28.2006, 01:01 PM
Griffinru; what does the sensor of the novak do? does it deliver a pulse? or does it change in resistance? Nice experiment.
i think it would be doable to make an external sensor.
Sneeck
RC-Monster Custom
Sneeck's Avatar
02.28.2006, 01:38 PM
On the back of the motor with some sort of plate. Could be sweet for sure.
