Steelerfan
03.21.2006, 07:57 PM
i moved the controller and seemed to help some. i'll move a little more until i get it right. thanks
ID:	947   Click image for larger version
Sylvester
Sylvester's Avatar
03.21.2006, 08:14 PM
That looks better, now go get and get her dirty:)
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
03.21.2006, 08:29 PM
I noticed you are using the stock AM receiver. AM by nature is very sensitive to noise and those high current wires can radiate quite a bit of noise. I see that the receiver and antenna is right near the BL motor, wires, and ESC. Moving the receiver might be easier than moving the ESC if you still have problems - maybe on top of the battery pack?
squeeforever
squeeforever's Avatar
03.21.2006, 09:11 PM
i would mount it on the front shocktower, facing the rear of the truck. you have plenty of antenna wire so it should be ok.
Steelerfan
03.25.2006, 05:33 PM
I've moved and/or replaced all electronics. The problem is getting worse. I think the esc may be the problem. I emailed mike for suggestions.
Steelerfan
03.27.2006, 07:58 PM
I can't seem to get an e-mail to Mike. Any suggestions?
Sylvester
Sylvester's Avatar
03.27.2006, 08:14 PM
rcmonstermike@gmail.com < try this email it should work now.
Losi 8ight e
Steelerfan
03.27.2006, 08:37 PM
thanks
