Finnster
KillaHurtz
Finnster's Avatar
02.09.2010, 02:48 PM
The ext chassis is 15mm longer IIRC. Not a lot, but enuf.
02.09.2010, 04:40 PM
Well, 15mm would make sense. That's actually quite a bit really; over 1/2 inch.
So, I guess from the responses here, either the Futaba or Hitec would be good. The JR probably would work, but I think I'll stick to a torque/speed spec that I know work well.
nitrostarter
nitrostarter's Avatar
02.09.2010, 04:50 PM
Go Futaba.
N. Rustler conversion
02.09.2010, 05:15 PM
I just called my LHS and the Futaba is the only one they have in stock, so Futaba it is!
jhautz
jhautz's Avatar
02.10.2010, 02:00 AM
Which hitec servo are you running? Like I said, I'm kinda leary about them, but maybe the newer 5245MG is better/more reliable than the older 225MG's I had.
I just looked at the JR site and the only digital mini seems a little low on the torque (51oz-in @ 6v), but the 0.06s speed is nice (although I probably wouldn't notice the difference between 0.12s and 0.9s in reality).
Hitec 5245 is what I had.
This is the JR I am using now. Best mini servo Ive found.
http://www.jrradios.com/Products/Tec...dID=JRPSDS3421
to make it...
or break it...
Silent...But Deadly
02.10.2010, 11:07 AM
I ended up getting the Futaba S9650. It is a hair narrower than the Hitec, but several mm longer. As such, the servo mount didn't need that little spacer that the Hitec did.
Put the new servo in last night and it runs great, and is quieter than the Hitec. And it seems to center much better too. I could never seem to get a consistent center with the Hitec, even when new, but I just thought it was the tire resistance or something.
Another thing about the Hitec 225MG: When I took it apart to troubleshoot, I found the power PCB is just floating around the servo case. It is encased in some heatshrink tubing, but the only thing keeping the board in place was the stiffness of the motor, pot, and servo wires. So, on hard landings/jumps, I'm sure that little PCB was smacking against the case, which isn't good for the components! Poor design. Hopefully, Hitec fixed this poor engineering choice in the newer model, but I'm not going to be another guinea pig!
