neweuser
neweuser's Avatar
04.13.2006, 11:12 AM
Well, i have an HV maxx that runs hot. even with 12/72 gearing. So i'm looking into getting something that can take a good beating yet keep on going. The Hv seems to be temp sensitive. On fresh batts it stutters and spurs too. i have a new reciever coming in that is 75MHz hoping that will help the stuttering, but still want more speed. 9920/9L is what I was thinking, but will upgrade more later. Need to know the diff between 9L vs XL i guess in price and stuff.
neweuser
neweuser's Avatar
04.13.2006, 11:20 AM
Ok I'm there. What does it mean when it says "basic XL 5000, 2400, etc"?
coolhandcountry
coolhandcountry's Avatar
04.13.2006, 11:26 AM
The 5000 is the kv of it. The xl 5000 turns 5000 rpm per volt. Same with the 2400 turns 2400 rpm per volt.
Peace!
Country
Help support the
Rc-Monster
Buy here
neweuser
neweuser's Avatar
04.13.2006, 11:31 AM
So if i'm going to go with 14 cells and a 9920, with upgrading more cells later, which would be the best? Still the 10XL?
neweuser
neweuser's Avatar
04.13.2006, 11:32 AM
Also, in the meantime, can you help me with the stuttering on my hv? After it runs a while it's fine, but with fresh batts is real bad...i bought a new radio and reciever on the way for FM 75MHz, will this cure my stuttering problem?
Thanks!
coolhandcountry
04.13.2006, 11:48 AM
I had a problem like that on mine. It only did it on 14cells. I couldn't figure out why. It was like the voltage was to hi.
Peace!
Country
Help support the
Rc-Monster
Buy here
neweuser
neweuser's Avatar
04.13.2006, 12:52 PM
That' s what I was thinking also. I'm in the process of getting things set up to air cool the motor with a fan, kinda like the set up with the esc. But not quit sure how to power that second fan.
neweuser
neweuser's Avatar
04.13.2006, 03:40 PM
Let me know how that system runs for you. Lipos? How hard are they to take care of?
If i run the 9920/9L, what gearing should i go for?
neweuser
neweuser's Avatar
04.28.2006, 01:46 PM
back to this thread. I just purchased 20 loose cells from mike. Is this too much weight on the emaxx? Also, just to confirm, will the controller handle it with the 10xl BK, or am i risking my system? Otherwise i could go 16-18?
coolhandcountry
04.28.2006, 04:07 PM
The 9920 on 20 cells with a 10xl should be fine. It is some weight for the emaxx to tote. You have to get it set up for it.
Peace!
Country
Help support the
Rc-Monster
Buy here
neweuser
neweuser's Avatar
04.28.2006, 07:07 PM
maybe i should run my 14's for now, resolder them, and get the one speed, and save for the gmaxx chasis carbon...lose 4 shocks(which i'm not sure how to set that up). The only prob is i heard the fast lane stuff does not work well with gmaxx, and i really wanted to use the hybrids.
coolhandcountry
04.28.2006, 07:33 PM
The hybirds and gmaxx work well. I have two of them now. It is ue and flm that seem not to work well.
Peace!
Country
Help support the
Rc-Monster
Buy here
neweuser
neweuser's Avatar
04.28.2006, 10:16 PM
So if i get he hybrids i should usewhat they call truggy 1/8 gears?
coolhandcountry
04.29.2006, 07:27 AM
The truggy gears are really low geared. I use the buggy gears myself. It would depend on the setup you going for.
Peace!
Country
Help support the
Rc-Monster
Buy here
neweuser
neweuser's Avatar
04.29.2006, 12:49 PM
Well, i like speed i guess. Maybe go for the ue 8 spyders and use their diff cups and stuff? But i heard they don't fit the fL bulks...is this true?
