Go Back   RC-Monster Forums > Support Forums > CORR Trucks - Slash, SCRT10, etc.
BAD 1
05.16.2010, 11:15 PM
Running the Novak Havoc Pro & HV 4.5 on my Jammin SC10. Has plenty of speed on 2s 50c, 5000mil with 14t pinion. Problem with ESP. Shuting down after 1 or 2 laps. Would stop for a couple of seconds then start up. Was not thermaling out. Switched batteries full charge and ran great. Got to mains with same battery and same prolem. ESP & motor were at safe temperture. Frend has the same set-up with no problems. Think I will put in my Tekin Pro in it.
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
05.16.2010, 11:46 PM
You probably need to send it in or warranty work...I got the same setup with my hyper10sc and it was shutting down prematurely...the novak tech said that there was a software issue with some of the escs...their low voltage cutoff was being too sensitive or activating too early...this is a simple software update BUT, you have to sent it in...j sent mine in last week and it's being looked at right now
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
BAD 1
05.17.2010, 01:03 PM
Thanks Hootie. I will be shiping it back to Novak.
