07.20.2010, 09:40 PM
Must be nearly 2lb each- not really designed for highspeed something tells me....
kladal
07.25.2010, 01:07 AM
I think I certainly need to get a beefier servo for this setup.
1. Does anyone have any recommendations on what server to use?
2. In the scenario I decide to go for four wheel steering, does anyone know if using a y-cable to jointly connect the two servos to the receiver will work?
Thank you!
steveo
07.25.2010, 02:24 AM
what length is the wheelbase, do you have anybody options yet
Jahay
07.25.2010, 05:27 AM
yes a y cable would work, so you can connect two servos to to the receiver. if your moving some chunky wheels... What about the hitec 7955 which has 24kg roughly or torque
kladal
07.25.2010, 06:10 AM
Jahay - how do I make sure the rear servo is reversed? Is there an option on the servo you recommended for this?
Steveo - from front to end I'm around 28" and what do you mean by "anybody options?" If you mean a raw plastic body, I'm using a Redcat Rampage MT 1/5 scale body.
steveo
07.25.2010, 09:18 AM
yes i meant body i was up to late, love the build as i was reading through the thread i was also lookin at my emaxx with an extended chassis considering making it huge and using some hpi 1/5 wheels and tires for a scale look
