mwe-maxxowner
mwe-maxxowner's Avatar
08.22.2010, 12:25 PM
what i have now is 62/18
Brushless-taking back rc!
E-revo is DONE!
  Send a message via AIM to mwe-maxxowner
mwe-maxxowner
08.22.2010, 12:26 PM
what is that link
E-revo is DONE!
redshift
RC-Monster Square Tube
redshift's Avatar
08.22.2010, 12:23 PM
Nope, just the opposite.
No more questions until you look at the calc...
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.22.2010, 12:38 PM
http://scriptasylum.com/rc_speed/_top_speed.html
redshift
redshift's Avatar
08.22.2010, 12:49 PM
Look here- http://scriptasylum.com/rc_speed/_wiring.html and click on "2 parallel pack wiring" for proper adapter.
mwe-maxxowner
08.22.2010, 01:18 PM
I have the emaxx #3903 the speed calculator asks me if i have #3905 what shall i do
E-revo is DONE!
redshift
redshift's Avatar
08.22.2010, 01:27 PM
Same transmission, just enter 3905.
hemiblas
hemiblas's Avatar
08.23.2010, 08:36 PM
So how are you going to mount those packs again? you can barely fit a 3s 5000mah with the optional battery hold down and due to their width they dont seat correclty in the battery tray. You arent going to be able to fit 6S on each side without some duct tape and rope.
mwe-maxxowner
08.24.2010, 04:17 PM
I know! Im so excited! I cant hardly wait!
DUCT TAPE! (and zip ties)
E-revo is DONE!
08.24.2010, 07:21 PM
I manage with 5s2p on my Gmaxx, but thats a very different beast..
hemiblas
hemiblas's Avatar
08.25.2010, 04:12 PM
What C rating did you get on those batteries? The higher the C rating the bigger the packs are. You are going to need some pretty big zip ties.
Hey Neil, So are you running 2 5S paralleled packs on an MMM on your Gmaxx? or is it a single 5S2p? What capacity? thats gotta be a big pack. I still say 5S is the sweet spot for the MMM, though.
08.26.2010, 12:11 PM
Its a pair of 5s packs yeah, one on either side of the chassis. They are big packs, but still lighter than 14/16 nimh cells and a million times more powerful
mwe-maxxowner
08.25.2010, 04:42 PM
I believe they were 20c.
E-revo is DONE!
hemiblas
hemiblas's Avatar
08.25.2010, 06:01 PM
You should parallel them for sure. People I know, including myself, have had back luck with the 20C zippies and the MMM on 6S. If you parallel you get 6S at 40C so thats better. I dont know for sure but I just dont recommend only 20C on a 6S setup anymore, no matter how low you gear it to keep amps in check. That of course only applies to the cheap batteries, I'm sure if you get some that are truly rated for 20C then you would be ok. I will be curious how your MMM holds up under 6S though and all that weight.
08.25.2010, 06:36 PM
It does not double the C rating- Paralleling the packs doubles the capacity. so you'd get a 6s 10,000mah pack - if 20C that would give you a theoretical 200amps continuous rating.
More than enough - Your car will be heavy though1
