supralover72
supralover72's Avatar
12.30.2010, 04:39 AM
The Baja was designed from the ground up to be 2wd. I feel like it's more than inferior for 4wd. If you want 4wd and 1/5 scale why not just an FG modelsport or something similar? Why waste all that money and parts for and inferior system?
BIG-block
12.30.2010, 04:57 AM
I'm not particularly fond of the belt system. When working on my nitro 4-tec conversion, making the belts tight enough so they don't skip on the pulleys adds a lot of drag to the system, which results in lost power.
I used to get little rocks destroy my belts on my TC just running on the street. I would hate to see what happens to those belts bashing through dirt and gravel. Also like you said Brian belts can be very inefficient. Still I love the idea of $wd 1/5th scal and brushless. Maybe check out something from the very expensive MCD range.
How?
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
How? - 12.30.2010, 06:48 AM
How would you figure even in the least that the 5b would be a bad 4X4? First off it is a rail style buggy, which in the world of a 1:1 are in a lot of cases 4X4. The 5b is in my eyes the best looking 1/5th scale R/C buggy being made, and with the way it is built can take a lot of punishment. So why would anyone want to go for an inferior design as an alternative. Converting any vehicle from 2wd to 4wd creates a less efficiant power curve, but the trade offs in basic handling are usually well worth the effort. If you put a 5b 2wd up against a 5b 4wd with the exact same powerplant, which one do you think will prevail? I would take the 4X4 any day.
SUPERMAXX YOUR LIFE.
doo540
12.30.2010, 07:03 AM
I really dont care for the "look" of the 4x4 FG models. I already have a HPI 5T and really like the looks of that so thats why I'm choosing the Kalee. I would rather buy a HPI 4x4 baja but those dont exist. I really dont think that using a Emaxx drive train and Proline 40's tires makes it a 1/5 scale model. Sure the wheel base will be long, but the overall parts will still be 1/8 scale. Thats another reason why I'm choosing to go this way.
Redcat will be releasing a 1/5 scale BL buggy this spring. There is a post on it somewhere on this site. That has the centerdrive shaft setup. Looks cool, but I perefer teh looks of the Kalee.
Semi Pro
Semi Pro's Avatar
12.30.2010, 07:14 AM
i agree, i perfer the look and style of the baja to most of the other 1/5's on the market, as for useing a 1/8 and turning it into a 1/5 i thought about it but there isnt a 1/8 on the market that will stand up to 10-12hp for long, add in bigger tires and the 1/8 diffs will fail even faster
doo540
12.30.2010, 10:00 AM
thats very true.
I'm not worried about making the BL work, I work at a Tool and Die shop so we all kinds of CNC machining. I think the belt will work just fine.
Just need some time and cash to start/finsh this project. haha
josh9mille
josh9mille's Avatar
12.30.2010, 10:47 AM
Not sure what 1:1 rail type cars you are talking about, but i have never in my life seen one that was 4x4. I agree with Supra on this one, the Baja is kind of an inferior design for 4x4, it seems really nose heavy when jumping and would probably only be worse with more weight in the front end from the drivetrain.
If you want a 4x4 Baja "looking" buggy then why dont you guys buy this: http://www.redcatracing.com/RC-Cars/...Rampage-DR-4X4 Dont worry, it is not a clone, it just looks similar to a baja.
brian015
brian015's Avatar
12.30.2010, 11:29 AM
I had planned to make a buggy that used the XTM XLB buggy body. Would not be as long as the baja, but close. Was going to use muggy/lst parts, custom shock towers and a 4-6" wide al channel with 1.5" tall sides as the chassis. Narrow and strong. Planned to run a center diff/spool with a side or top mounted motor just like the rcm conversion parts for 1/8 buggies. Being long the motor and center drive could be closer to the rear and the batteries would be at the front. 4wd of course. Need to mock it up again so you can see what I am thinking...
Kinda like this?
thzero
12.30.2010, 11:52 AM
Brian,
Got pics of how you mounted the rear of the Baja rollcage?
brian015
brian015's Avatar
12.30.2010, 12:12 PM
Originally Posted by thzero View Post
Brian,
Yep:
http://www.rc-monster.com/forum/show...t=26979&page=5
brian015
brian015's Avatar
12.30.2010, 12:24 PM
If you scale up an 1/8 scale truck, it won't weigh as much as a Baja - so you won't need 10-12hp through it. This past summer I built and tested this:
http://www.rc-monster.com/forum/showthread.php?t=26979
It weighs 19lb with batteries. I run it on 8s geared for 50mph and have logged nearly 5hp through it:
http://www.rc-monster.com/forum/show...t=26979&page=7
I've had no problem with the Muggy/LST drivetrain with this weight and power.
doo540
12.30.2010, 12:59 PM
thats a cool build.
I'm going for more of a Monster truck type build.
I really like the large tires. I know that large tires are hard on everything, but thats teh style I like. My 2wd BL 5T weighs 30lbs ready to run. It does have 8.5 tall tires too.
Its cool to have more then one style of truck running around. I've just grown tired of the XXL stuff (I currenlty have 2 BL XXL's).
12.30.2010, 02:59 PM
Wonder why we have not seen something like a scaled up 1/8 buggy/truggy... Sorta like the redcat 1/5 scale. I would go with something like that to covert over a 5b.
I was planning on taking a mbx5T and stretching it to a 5th scale size. Making the longer chassis is simple enough as well as having longer center drive shafts can be had as well. My only hesitation was the a-arms not being wide enough. I felt that the stock 5T arms would not be wide enough for my liking. Another 1" wide 2" over all would be perfect. In saying that, if someone could cut some quality plastic arms to those specs...then you would have something.
The truck then would be fairly light and even on 6s it would go fairly well..
Just my 2 cents worth
brian015
brian015's Avatar
12.30.2010, 03:29 PM
My solution:
Pro-line hex extenders - so far, they have held up to many tumbles and cartwheels without problem.
Edit: They're 23mm hexes, so with a wrap or two of aluminum tape, they fit the Baja 24mm wheels perfectly.
bigsteel
12.30.2010, 06:59 PM
Phatdad rc is going to be making plastic boxed in arms that are 1pm wider on each side than stock.they are the boxed in type found on 1:1 rigs.--Josh
