Go Back   RC-Monster Forums > Support Forums > Team Tekin
Mikey007
01.19.2011, 07:30 PM
Just checked they are 105 degree caps!
I might have an issue I never thought of though. I run a 2 speed, I won't be able to use the motor brakes as the one way in the trans will just allow the trans to free wheel anyway. Anyway around this? I know I could switch to a single speed, but is there any other mods to keep the two speed?
01.19.2011, 07:38 PM
You are right, most 2 speeds use a one-way bearing, which makes using the motor for brakes or reverse impossible. You'll need to lock it in a single gear, or use a center diff setup, or some other mechanism (like the old style emaxx transmission where there was a shift fork to manually shift).
Mikey007
01.19.2011, 08:21 PM
Ok. I need to rebuild my trans anyway, so I will get the hd gears and single speed it. Thanx
