Originally Posted by Semi Pro
this is rc monster we make room
as for belts holding up to power, belts are fine and if they do fail im sure alot of companys will make better aftermarket belts too, just by lookingf at the size of the belt its easly as thick as my serpent belts that hold up to a 1512 on 6cell with out trouble
I'm sure there will be a way to cram it in there, I know someone here will probably even try putting a 1518, 1520, or 1717 in it
. However I think that with the 1410 it will still be plenty of power and be worthy of wearing a RC-Monster sticker on the shell. 2wd or 4wd it doesn't matter, you can only put so much power to the ground with SC tires, even good pin tires will only hook up so much in dirt with such a light truck. Not trying to doubt you or the rest of the monster crowd, just stating what I have figured out from experience
