neweuser
neweuser's Avatar
04.28.2006, 02:25 PM
thanks man. the reason i got it was because it could take 20 cells. i'm runnin ib3800's
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
also just be carefull....cause it could go "POOF"......drop me a email tonight if you have any Q's.....good luck
sjcrss
sjcrss's Avatar
04.28.2006, 02:37 PM
the type of cells are fine.....just watch the # of cells.....keep in mind your running 24 Volts thru the controller........also can the motor handle the rpm.......I think the max RPM it can handle is 80,000 rpm....and with a rpm rating of 1502 per volt.....* 24 V you will be running at a rpm of 36,000 give or take a few.....which is fine for the motor.....just sharing some info with you......LMK how it goes....
neweuser
neweuser's Avatar
sure thing. i'm still waiting for that darn ubec...talk about slow. shoulda ordered it from mike...would've already had it! I won't have the cells for awhile unless Mike gets a REALLY good jump on the shipping....
Gustav
Gustav's Avatar
04.28.2006, 02:41 PM
Originally Posted by neweuser
Not to hijack, but can you run 20 cells on the 9920? cuz i just bought some...will it get hot?
I was running 20 gp2200s on a 9920 for a little while and it didn't get too hot,130F after 10 mins without a fan and no ventilation in the body,but i doubt they hold as much voltage under load as good subCs but they're alot smaller and lighter(4/5th subCs).Also it was a 1300kv motor so little milder on 20 cells.
I wouldn't hesitate to run it on 20 cells personally but put a fan on the controller,that's what i would do with a 10xl,it'll bring that motor to life for sure.
sjcrss
sjcrss's Avatar
04.28.2006, 02:49 PM
heat isn't really the issue with the controllers.......you can allways keep it cool with a fan and good ventilation.....the issue is the voltage spike and or amps that can suddenly go to the controller from the batts.....and it will fry it......like the post I posted earlier...I fried mine on just 12 cells with a amp spike of 123 amps on a 1895 controller......
neweuser
neweuser's Avatar
04.28.2006, 03:12 PM
Thanks for the input and sorry for the jack!!!
sjcrss
sjcrss's Avatar
04.28.2006, 03:17 PM
the same here..for hijacking the thread.....but sometimes I think people get absesed with speed and power and forget about all the little things that can affect the controller ect......speed and power is nice but at what price...a fried controller...
coolhandcountry
coolhandcountry's Avatar
04.28.2006, 04:35 PM
I have ran and still run 20 cells on a 9920 with no problems. The esc does not heat up either. I run it on a 1950 hi amp 8t. Dafni has pulled a 130 thru a 9920 as well. I don't think the 20 cells will hurt. The 10xl has a low amp draw to. So that makes it better and easier on the esc as well.
Peace!
Country
Help support the
Rc-Monster
Buy here
neweuser
neweuser's Avatar
04.28.2006, 06:59 PM
thanks coolhand, sjcrss. when i get them, i think i'll go for it!! If i fry it, well, knock on wood, i'll have my old lady by me one!! TEHE, the least she could do since i'm building her whole truck and paying for it!!! Except the tranny i think she paid for that....
coolhandcountry
04.28.2006, 07:42 PM
If I thought you would fry it I wouldn't recommend it.
If you run the 20 cells drop back some on the pinion gear. give you longer run time. I think it will be more than you want but that is the fun part. :027:
Peace!
Country
Help support the
Rc-Monster
Buy here
sjcrss
sjcrss's Avatar
04.28.2006, 08:04 PM
newe...I'll cross my all my fingers and toes for you......"this comment is to everyone....." I wasn't trying to "P" anyone off....but I was just letting people know what the risks can be.....sometimes your lucky..sometimes your not.......I got into the Bl scene back when "modeltech" did Bl systems which was a re-packeged hacker motor and a schultz controller......so basicly I think around the year 2000......so I do have some expertise......and I do respect everyone else's expertise also....
coolhandcountry
04.28.2006, 08:14 PM
It is all cool sj. It is hard to say for sure if that 128 amp was the cause or not. It may have been on its last leg when it shot the 128 thru it. I have been running the 9920 on 20cells for a while now. MONTHS Just remember you can use a tv for years and it blow up at any time.
Peace!
Country
Help support the
Rc-Monster
Buy here
sjcrss
sjcrss's Avatar
04.28.2006, 08:39 PM
you got a valid point....you just never know with electronics......
