mrtallica
mrtallica's Avatar
04.30.2006, 08:19 PM
I was looking at using these tires from IMEXrc
K-Rock Tires
Height: 6.50"
Width: 3.5"
Diameter: 3.2"
  Send a message via Yahoo to mrtallica
coolhandcountry
coolhandcountry's Avatar
04.30.2006, 08:44 PM
For that size tire you would need good diffs like the 1/8. Not only that but the oil in them helps with slip to. I would go for a14 51 gearing with the 1/8 diffs. Just my suggestion for keep the maintance and breakage down.
Peace!
Country
Help support the
Rc-Monster
Buy here
squeeforever
squeeforever's Avatar
04.30.2006, 09:40 PM
One thing I see very wrong is your choice of batteries. The new GP's arent worth a damn so i've heard. I know for a fact that you'll like the IB 4200's as I have some myself. I have hear numberous things about the GP's not holding there voltage under load. The IB's are no doubt the way to go.
mrtallica
mrtallica's Avatar
04.30.2006, 11:56 PM
Thanks everyone.
coolhand. do you have a link the diffs you are talking about?
Squee: thanks, i will check intot he IB's, they should not be too much more should they?
coolhandcountry
05.01.2006, 04:19 PM
Mike has some in the store they are hot bodies diffs. Don't get the pro cause it has a lower diff ratio. http://www.rc-monster.com/proddetail...GY_DIFF&cat=47
These would be great to put them in. http://www.rc-monster.com/proddetail...LM18700&cat=47
You can get these from mike as well. If you want to keep your bulkheads you have. http://www.unlimitedengineering.com/...ore/13540.html
or a stronger one http://www.unlimitedengineering.com/...re/13540B.html
Peace!
Country
Help support the
Rc-Monster
Buy here
mrtallica
mrtallica's Avatar
05.01.2006, 08:18 PM
so, if i went with those particular tires, i would need that set up. but just the controller and motor, i would be fine with just the CVD's for now? Limited budget so i have to do this in phases...sux:019:
coolhandcountry
05.01.2006, 08:49 PM
Well you can run the stock diffs but they won't last for ever. I like big tires as well. They are hard on drive line though.
Peace!
Country
Help support the
Rc-Monster
Buy here
Mike.L
Mike.L's Avatar
05.01.2006, 08:53 PM
your going to need mod 1 pinions.
  Send a message via MSN to Mike.L
Sylvester
Sylvester's Avatar
05.01.2006, 09:01 PM
They are talking about differentials...
The stocks may last a bit, but like CHC said, they wont last forever. Even a aluminum cup properly shimmed with aluminum diff cases should last atleast a year or so. A perfectly shimmed stock diff will last longer than a unproperly shimmed aluminum diffs.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
