TexasSP
Something, anything, nothing
TexasSP's Avatar
08.13.2011, 09:05 AM
I picked one up because the deal was so good and the fact prices have gotten so high.
Without those two factors together I would not have. I have no application for this motor at the time so it will sit until I do.
I really don't know what I anticipate doing with it at this moment. I just knew that they would go fast and it would be a good motor to have for different applications.
www.cubicle101.com
j.f.s
08.13.2011, 04:56 PM
Yeah, was the same for me and since I've got a 1518 and the repair kit for it is non existing I thought that $70 for a quality motor is a deal too good to pass up on.
I know that the 1515 repair kit can be used for the 1518, apart from the rotor, but the price tag on that kit is in the $45-55 range. I'm still beating myself up for not buying two 1518's during the last sale.
CerberusVI
CerberusVI's Avatar
08.15.2011, 08:00 PM
Well i ordered a 1717 the other day when this was posted and just received it..Now i know why these 1717s where in the corner of the warehouse... I got a 1717/17 1580kv with a 6mm shaft and closed endbell. which is odd because the heli version has 6mm shaft and open endbell... I'm kinda frustated at this point..
brian015
brian015's Avatar
08.15.2011, 08:13 PM
IIRC, the first batch of the car version was mistakenly made with the 6mm shaft.
CerberusVI
CerberusVI's Avatar
08.15.2011, 08:15 PM
and I guess that's the one i got
08.15.2011, 09:55 PM
No worries, you can buy 6mm bore pinions, or you can just do like 99% of other guys did in your situation and grind the shaft down; all you need is padded vice and a metal file / dremel and some digital calipers. Stick the motor in a bag and poke the shaft through it to keep out the filings, then work back & forth along the shaft ( ahem.. ) and keep checking until your 5mm bore pinions fit snuggly. Either that, or sell your $70 motor for a large profit on a heli/ plane forum...
TexasSP
TexasSP's Avatar
08.15.2011, 10:10 PM
I think I just dreamed up a use for mine. Looking at building a scale 6x6 beast. Thinking the 1717 on 4s will be perfect. This thing will be heavy so I need a ton of torque.
www.cubicle101.com
FG101C
08.15.2011, 11:53 PM
poke the shaft through it, then work back & forth along the shaft ( ahem.. )
ROFL that made me laugh.
Pdelcast
Pdelcast's Avatar
08.16.2011, 05:07 PM
SORRY guys, unfortunately these motors were made with a 6mm shaft (that's why they were off to the side in the warehouse.)
If anyone is unhappy with the fact that they got a 6mm shaft, please let me know. We will give a full refund to anyone who wants to return the motor.
(P.S. -- I didn't know about the sale until after the motors were gone ... and I would have suggested charging $150, and not $80 )
Thanx!
Patrick
Patrick del Castillo
President, Principle Engineer
freddy
08.16.2011, 05:27 PM
Is it possible to drill out an 5mm pinion to 6mm with an normal hand held drill?
im using novak ones, if it makes a difference(found them to be the best durability wise)
and Pdelcast it was 70usd not 80
1truckerdan
1truckerdan's Avatar
08.16.2011, 05:31 PM
CC thank you for the price break, some of us are very greatful for the chance to own these motors.
1truckerdan
The bore HAS to be dead center. Use a drill press!
freddy
08.16.2011, 05:45 PM
the drill will follow the existing hole, right?
Was more concern about the hardness of the pinion than getting it 110% straight, guess i just gonna give it a try. dont have an drill press, and dont want to bug other to help me
if i sand the shaft down from 6mm to 5mm, i think there will be more risk about getting it straight than drilling the pinion. atleast its better to risk a pion than the shaft.
TexasSP
TexasSP's Avatar
08.16.2011, 05:56 PM
Thanx!
Patrick
For 70 bucks I'll deal with the 6mm shaft.
I am just happy to be getting one since I already came up with a need for it. I wasn't sure then some planning and ideas just all came together and the motor will fit the bill perfectly.
www.cubicle101.com
freddy
08.16.2011, 06:01 PM
Castle is gracious
