crazyjr
crazyjr's Avatar
12.01.2011, 06:42 PM
Ok guys, one last question. What would happen if i used super glue (cyanoacrylate), to set the parts in position, then used the epoxy for final setting? Is there a chemical reason not to?
thanks guys, this is a good discussion.
PBO
RC-Unobtainium
PBO's Avatar
12.02.2011, 04:03 PM
Good question - I'm not really sure how CA & epoxy will react
What I would do is mix epoxy & 'glue fibers' (you could use talc powder) to stiffen the mix until it's as viscous as cold honey, then glue your components with that (You will need to add black pigment powder if you don't want to see the glue) & 'cove' the excess away using a tight radius to leave a smooth fillet
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
pinkpanda3310
pinkpanda3310's Avatar
12.03.2011, 12:00 AM
Have you got some small off-cuts you can test with?
