fastbaja5b
fastbaja5b's Avatar
02.01.2012, 09:24 PM
Ok so I know the sequence to plug is connect neg, connect non spark, connect positive but then do we disconnect the non spark resistor or do we leave it plugged in?
Say Less, Do More.
02.01.2012, 11:01 PM
You can safely remove the non-spark after you have charged the caps up and plugged in both the neg & pos battery connectors.
coolhandcountry
coolhandcountry's Avatar
02.02.2012, 09:35 AM
Would it be easier to just get a small switch of some sort.
Mount the switch on the R/C and plug the hot wire side into the switch.
Plug battery on other side of switch.
When ready just throw the switch and no spark ready action.
Just a crazy idea.
Peace!
Country
Help support the
Rc-Monster
Buy here
02.02.2012, 10:49 AM
Just a crazy idea.
If I'm reading that right, it's not a good idea. For one, you would one very large and robust switch to be able to handle the current requirements. Second, there is still a spark, it's just happening inside the switch.
magicald
02.02.2012, 12:41 PM
here's the info I found on spark arrestor resistors
http://scriptasylum.com/rc_speed/nospark.html
http://rc.runryder.com/helicopter/t547501p1/
They seem to suggest keeping it hooked up and say that electricity like water will take the route of least resistance and therefore the resistor hooked up doesn't matter.
I haven't messed with a resistor yet...will be a while as my XL2 crapped out
02.02.2012, 01:08 PM
A quote from the no-spark page on my site:
In both diagrams, the small connector should remain connected to prevent accidental shorting against any conductive surfaces, and to keep the contacts from getting dirty while running. Even though the small connector is hooked up at the same time as the main connector, the main path of current flow will be through the main connectors.
rcs2022
02.02.2012, 05:41 PM
In replying to your first question, i have the same query as you do (MMM + 1717 = safe?), although i have run it on 5S in an extended Savage Flux to XL length just recently (in my separate build thread), maybe couple of runs only. I would really like to go to 6S although have my fears. Done my homework and searched a lot, and only got mixed opinions. Essentially i firmly believe that it all come down to the gearing and the weight of the truck/car; may try to gear down a tooth or two om my pinion and try 6S.
Given the same setup would going from 5S to 6S add more amp draw? or the increased voltage would give the more power at roughly the same amp draw?
If I recall correctly the 1717 was offered as a package with the Mamba Monster on the same page, does it mean anything, i dunno. also searching for the answer.
Might do as others have done and get myself a MMXL.
fastbaja5b
fastbaja5b's Avatar
02.03.2012, 05:41 AM
Well got a resistor, this one do the job for 6s?
Will use a 2mm bullet plug to hook it up between the positive leads on the esc and the battery next to the 8mm bullet plugs I am using to connect the ESC to my 6s Lipo.
Say Less, Do More.
freddy
02.03.2012, 10:10 AM
The Mamba Monster will do fine, it is just crucial to have quality lipos and connectors.
02.03.2012, 10:53 AM
10 watts is a little large, but won't hurt anything, just be more difficult to install. 1 ohm is perfect for 6s though...
Cain
06.14.2012, 11:02 AM
Sorry to bring up an old thread, but I figured it was better than just starting a new one that basically is related.
Anyway, just some background info I am hopeful will help.
I have been toying with with the idea of doing one of those 5SC Flux style conversions (though in buggy form) using a TCS or Alza Racing conversion to an HPI Savage Flux. I am thinking right now of using 6S setup, possibly with the MMM and 1717 motor combo, maybe even that new traxxas MMM and the XO-1 1717.
Anyway, I wanted to know a few things first:
- I have heard of people running external BECs, however, if that for some reason fails, does it usually send all the voltage to the servos, receiver, etc? Would it be better to run an external receiver pack in that case instead if you have this concern? If so, has anyone done this and what did you need to do to get your wiring correct?
- Sorry if this is really easy info here, but I am still trying to wrap my head around it. So, for 3S dual lipo use in series with the MMM, do I need to worry much about the whole spark thing or is it more so when you have greater than 4S going through one connector?
- For dual 3S lipo use to total 6S in series, are the deans connectors still useful or are they out of there element and should a different one be used? (I am assuming they are based on what HPI is doing with there 5SC Flux)
- What is different between the traxxas XO-1717 and the original 1717 motor and can you use the traxxas one fine in offroad?
- Any thoughts on the new "extreme" MMM? Is it worth looking into or is the MMM sufficient for what I am looking to do.
- Lastly, would a 1520 motor be a better selection than a 1717 in your opinion in a 1/5 "Flux" style vehicle? If you feel so, can you state why?
Thank you everyone before hand for any help you can provide. I really appreciate it.
06.14.2012, 12:15 PM
1: Yes, ANY switching BEC can fail like you describe, although it happens more if you are pulling larger currents which stresses it more. A receiver pack is obviously better in this regard, but is just one more thing to charge up, and I would personally use a 2s LiFE pack instead for flatter discharge curve and higher capacity.
To use an external receiver power source, you'd simply remove the red wire from the ESC's throttle cable. This will keep the ESC's BEC from powering the servo/receiver.
2: No matter how you arrange it (1x6s, 2x3s, 3x2s, etc), a 6s pack will have the same amount of spark. And whatever connector type you use, the spark will happen on the last connection you make.
3: According to Patrick (Castle pres) the Traxxas 1717 has slight design changes for faster spool up and higher efficiency at higher currents. Kinda makes sense in an on-road vehicle that is geared stupid high.
4: By "extreme MMM", do you mean the MMM included with the Traxxas XO-1 or the one for 5th scale? The XO-1 ESC has two main differences: has the speed lock-out firmware which requires the iDevice to unlock and has an additional capacitor bank. Personally, I would just use a regular MMM and add some capacitors to the power leads.
5: Not sure really but the 1717 does have a slightly higher continuous power rating. Either motor would probably work well.
Cain
06.14.2012, 12:18 PM
Thanks for the info Brian I appreciate it!
Definitely give a regular MMM a look again then.
