fastbaja5b
fastbaja5b's Avatar
03.05.2012, 09:01 PM
Any time you use a Castle Esc you should have a Glitch Buster cap in there, even if you are just using a S3003 std servo!
Say Less, Do More.
BADBOY2
03.06.2012, 04:44 AM
so i just need to buy glitch buster then?do you need to solder it or it connects to the receiver?
03.06.2012, 08:17 AM
If you buy the novak one it comes with everything.
BADBOY2
03.06.2012, 11:06 PM
does it work as bec too or just to prevent radio glitch?
03.07.2012, 05:45 AM
A glitchbuster is just a capacitor - just helps stop voltage dipping in rx and it glitching
BADBOY2
03.07.2012, 01:41 PM
thanks!i bought a rx8 instead so my worries of frying my esc ,coz i dont have bec are gone..i hope i wont need a BEC on the rx8?
03.07.2012, 04:07 PM
You do understand that the BEC is a component built into the esc; the use of a glitch-buster capacitor or an external BEC is only required if the built-in BEC isn't man enough, or doesn't provide enough voltage for a HV servo for example. I have no issues with the MMM's built-in BEC when using a pair of 1/4 scale digital servos in my TXT-1, or a single digital servo in my GorillaMaxx; I run a glitch-buster cap on each rig as a precaution, but no issues so far..
