wellby
wellby's Avatar
03.23.2013, 12:09 AM
Thanks the only reason I'm using a summit trans is because I had a Summit I wasn't using at the time. Need to put it back in the Summit I possibly will be changing it over to a 1 speed trans no real need for the low gear I dont want to see what it would do the diffs if I got a wheel stuck
03.23.2013, 12:20 AM
Who made the mount and the spur gear slipper setup?
03.23.2013, 12:23 AM
If you can find the nova rc al diff cups and the sportwerks tin coated ring/pinion gears you can make a bullet proff set of diffs for the truck. I did mine about 5yrs ago and they are still going strong with the 1717 and lst2 tires/wheels.
I ran some power thru the 1sp new emaxx trans and it did fine. Good synthetic grease is important in there. Or seal it and run oil additive, like sikeston does.
I plan to make another wide ratio 2sp trans up for my 6x6 max truck. Another outrunner project, most likely on 5-6s.
wellby
wellby's Avatar
03.23.2013, 12:48 AM
The mount is the Kershaw Desings for a Summit running the CC1520 it raises the motor enough to clear the shock mounts on the Summit and the slipper is a RRP slipper set up for a slash 4x4. I may convert back to the stock motor mount to lower the motor or just use my 1717
Relocated the batteries
wellby
wellby's Avatar
Relocated the batteries - 03.23.2013, 09:02 PM
Moved the batteries to the sides, made a simple tray that is mounted between the frame and lower skid plate and mounter 2 rc monster universal battery trays
to lower the CG a little. Going to try and get some videos
ID:	10625   Click image for larger version
ID:	10626   Click image for larger version
