08.27.2013, 07:08 AM
If that wire is not needed for series charging then they haven't really fudged it up then. They've made it so the correct wire gets left out. Each tap can still be used on a stand alone balancer if needed.
What I am worried about is which tap from the battery pack goes first
It's not the correct wire getting left out though, they are tapping into both grounds and thats no good. It should only be one ground going into the charger. My description above explains it.
A simple use of the voltmeter will show polarity and which lead goes where.
pinkpanda3310
pinkpanda3310's Avatar
08.27.2013, 07:14 AM
The schematic I copied/pasted does the same thing though, doesn't it? The middle positive lead gets left out.
08.27.2013, 03:00 PM
Yep.
08.27.2013, 05:25 PM
I assumed the black wire was the negative. If I'm wrong on that assumption everything I've said is hogwash. Consult your voltmeter!
PBO
RC-Unobtainium
PBO's Avatar
08.27.2013, 07:13 PM
Voltmeter - check
Thanks guys, all the input is much appreciated. I think I have the direction I need
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
