JThiessen
JThiessen's Avatar
07.08.2006, 01:22 PM
They wont, since the 12t motors are only for 7.2V use. If they are gonna use the Super Duty XR than they need 2.
I'm not sure that I follow this...are the 12T motors different than the current titans? I would naturally assume that you'd run two of them in a truck the size of a maxx or revo, so the super duty would be a perfect fit, correct?
cemetery gates
07.08.2006, 09:03 PM
the 12 turn 550 in the stampede and rustler is made to run of 7.2-8.4 volts. the current titans are made to run on 14.4-16.8 volts and are 12 turns insted of 23.
JThiessen
JThiessen's Avatar
07.10.2006, 11:20 AM
So the EVX does not split the 14.4 volts from the batteries in to two 7.2 volt supplies to the motors? I was under the impression that all of these RC Brushed electric motors were essentially the same (disregarding physical attributes such as windings, can size, etc) in their Voltage input requirments.
