Originally Posted by mwe-maxxowner
What would I enter into that speed calculater for a revo with stock diff.s, an e-maxx tranny with stock two-speed, geared 70/12, and 70/13, and an hv6.5. Also with an hv4.5? I'm mainly concerned what to put for the diff.s and tranny, I don't know stock gear ratios, and am no good at calculating gear ratios.
There are drop-down boxes that let you select some preset values.
For the diff, just use the drop-down box and click on the Revo. It'll fill in the correct value.
Same thing for the tranny. Use the next drop-down and select the emaxx tranny. There are two entries; one for first gear, one for second gear. You probably want to pick 2nd gear. Again, it will fill in the right value.
For the spur/pinion, just enter the tooth counts in the appropriate boxes.
The same goes for the voltage. You can either type in the value, or use the two boxes and pick the values and it will do the work.
The motor drop-down has a bunch of different motors to choose from. When selected, the correct kv rating will automatically be filled in. If you know some of the kv values of the various HV motors, let me know and I'll add them to the listing.
If you make some obvious mistakes, the program will most likely let you know. I've built in error trapping and warnings when possible. BTW: if you have any ideas to make it better or more user-friendly, please let me know!
