and gearing, i will use the kyosho plastic spur from the rc monster store that is 46 tooth i think, im thinking a 15t pinion. what would you guys recomend
9xl will be the motor and i will be running 16 cells. two 8 cell packs.
in the future when i get more money i will invest in a nice lehner or neu motor.
Is the motormount part of the diff-holder or is the motormount a 'stand allone' type of mount? normally; with nice pinion (read beefy) you got the ability to have the pinion for 3/5th on the shaft and still be fine. In theory, the further the actual gear sits from the motor, the faster the bearing on the side of the pinion will wear out.
The 15 tooth sounds like a good strating point. 16 cells on a 9xl should be nice.
I would try to make a motor mount and diff holder together less chance of
flex between them.
Peace!
Country
Help support the
Rc-Monster Buy here
