12.03.2006, 11:10 PM
Yeah, the shape of the teeth from a normal steel pinion and a hardened steel spur are different and bind quite a bit. You can even tell that by trying to spin the pinion on the spur by hard. The binding was probably what made it go slower and is definitely where the filings came from!
I'm not really sure what tooth pinion you'd need. I would use this page to figure out what pinion you need. First, enter all the values from a stock emaxx except leave the top speed blank. Write down the top speed and overall gear ratio. Then, clear the form and enter the total gear ratio and top speed calculated from before and the rest of the values, but leave the pinion blank this time. The calculator will figure out the pinion to use to get the same overall gear ratio and top speed.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.03.2006, 11:35 PM
Oh, okay cool. I was dead on, i had 45mph for a 14 T, and 52mph for a 16 T pinion.
Serum
Serum's Avatar
12.04.2006, 12:28 PM
When you start using a 10T mod 1 pinion, the problems will rise, the gear is simple too small to make a good contact with the spur.
For your project, i would personally get a centerdiff instead of a sollid axle, this takes away a huge amount of stress from the drivetrain, and they can be bought on ebay for 25 bucks. 5 bucks for a mod1 51t spur and you'll be fine.
BitHed
12.07.2006, 10:34 PM
...I use a 66t 32p on the hellfire center diff...The spur is from the E-savage so its 'essentially' the same as an E-Maxx...Its goes fine, no problems, but i will be changing back to a Mod. 1 Kyosho spur...Just makes sense (to me) to go with 'chunkier' teeth...
