jhautz
jhautz's Avatar
04.11.2007, 05:09 PM
The idlers in an emaxx tranny are wider gears, which results in a larger contact area between the gears spreading the force over a larger surface. The steel spur gears are all very thin faces which concentrates the force in a very small area.
Plus a little lube in the emaxx tranny goes a long way.
to make it...
or break it...
Silent...But Deadly
Serum
Serum's Avatar
04.11.2007, 05:10 PM
Yes, but they have got a 3 times larger contact area. But steel on steel can work, no doubt.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.11.2007, 05:12 PM
Steel spurs... I bought a RR steel 72T spur back in the day with my STOCK emaxx, and it was eating my pinions up very quickly. 15 packs through it, and the pinions were razer blades.
Dafni
Dafni's Avatar
Yeah, works for nitros too. Just a matter of the right pinion.
04.11.2007, 05:26 PM
Well, I plan to see. It would be nice to be able to use steel pinions on some apps where using a plastic spur simply requires too much modification (CRT.5). It would also be nice to use the steel spurs simply because all the buggies come with them stock.
At any rate, I'll see how they do. If anything, I think I'll see greater wear on the Hyper 8 since it's a heavier vehicle, geared way too high (46/16) on a high kv motor (kv=2600 on 4s). Oddly enough, everything stays cool despite that.
GorillaMaxx360
GorillaMaxx360's Avatar
04.11.2007, 07:10 PM
what kind of lube should you put in your emaxx tranny and how much
04.11.2007, 08:08 PM
I got a small tube of what looks like white lithium grease from my LHS. All the tube said was "Losi brand lubricant" or something like that.
jhautz
jhautz's Avatar
04.11.2007, 08:09 PM
Stock you dont need any the plastic is slippery enough, and most dont use any even with the streel idlers. I like just a little light grease in mine when I run the steel idler. I just like to a little something in there for the metal to metal of the top gear to the idler. Some say it adds a little resistance to the transmsion, but its so little that there is no way you can tell. At least I cant, not even by hand. Another thing it seems to keep the gears a little quieter. Less gear whine. I like quite.
to make it...
or break it...
Silent...But Deadly
04.11.2007, 08:13 PM
Yeah, the grease adds a little stickiness (I guess that's what you would call it), but it sounded smoother when I used some. Doesn't take much. I just put a small dab on 3 spots of one of the gears and just spun the output shaft slowly until all the gears were fairly evenly coated. If you dab grease on the gears and then run it WOT, the grease will fling off onto the walls of the tranny which doesn't do much good.
Dafni
Dafni's Avatar
04.12.2007, 02:12 AM
As for the XRay XT8, I was looking forward to this truggy for so long, but now it seems that the XRay crew made some cost cutting changes since the XB8 that I will wait until they release a TQ version. Gotta love the no-C-Clip attitude of the buggy... going back is out of question for me... let's hope they bring a TQ or EC soon!
DAF
Mr.lst
04.12.2007, 02:25 AM
Brian choose a side autobot or decepticon! You can't be cool with both! J/K!
GorillaMaxx360
04.12.2007, 07:58 AM
how about associated black greese. brian if i went to my lhs what would i tell them in order for them to know what that losi greese is.
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
04.12.2007, 02:56 PM
dafni, this model is the top level xt8.
no others will come out till next year i suppose.
losi 8ight-t
xray xt8
Dafni
Dafni's Avatar
04.12.2007, 03:53 PM
I know, I keep following the XRay news too. But I still hope they'll bring out a TQ soon.
jollyjumper
RC-Monster jumper
04.12.2007, 04:13 PM
hey dafni,
would an entire kyosho or hotbodies center diff + mount not fit the xray chassis'?
losi 8ight-t
xray xt8
