02.13.2007, 04:04 PM
C to F conversion: F = C * 1.8 + 32
F to C conversion: C = (F - 32) / 1.8
0C is 32F...
neweuser
neweuser's Avatar
02.13.2007, 04:06 PM
Originally Posted by Bomb-Proof
150f is nothing to worry about. We have run other ESCs around 185F and never had a thermal. Then again, mine also hit the melting point of aluminum and didnt thermal :002: :036:
I don't believe that actually. Here is the specs of the melting point of aluminum.
Symbol: Al
Atomic Number: 13
Atomic Mass: 26.981539 amu
Melting Point: 660.37 °C (933.52 K, 1220.666 °F)
Boiling Point: 2467.0 °C (2740.15 K, 4472.6 °F)
Number of Protons/Electrons: 13
Number of Neutrons: 14
Classification: Other Metals
Crystal Structure: Cubic
Density @ 293 K: 2.702 g/cm3
Color: Silver
British Spelling: Aluminium
IUPAC Spelling: Aluminium
With that said, the solder on the wires, or solder anywhere in the esc would not last, nor would the circuitry, FET's, BEC, any of it.
neweuser
neweuser's Avatar
02.13.2007, 04:12 PM
0C is 32F...
I was close!
02.13.2007, 05:39 PM
Doesn't the type of aluminum affect the melting point (2032, 6061, 7075, etc)?
newe: Yeah, you were "close", but I was just letting you know the formula for future reference. ;)
neweuser
neweuser's Avatar
02.13.2007, 05:45 PM
No prob....all well and good sir. I usually use the burnt finger technique! :005: :013:
And yes, the grade of aluminum does matter when it comes to the melting point. The better the grade, the longer it takes to melt due to the higher temp it needs to be at. this has to do with the alloys in it to make it stronger. But the point I was making still stands I would believe. The info I sent is general and is used as a guideline.
02.13.2007, 05:54 PM
I don't mind the burnt finger technique... as long as it belongs to someone else! :)
I thought the type of Al would make a difference on melting point. Maybe BP used a really low grade aluminum?
neweuser
neweuser's Avatar
02.13.2007, 05:56 PM
Then the quality would have been a tad more then solder....:eek:
02.13.2007, 05:59 PM
lol. True.
t-maxxracer32
t-maxxracer32's Avatar
02.13.2007, 06:15 PM
wow im lost.
neweuser
neweuser's Avatar
02.13.2007, 06:32 PM
Originally Posted by t-maxxracer32
wow im lost.
Sorry about the hijack!
glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.13.2007, 07:20 PM
I think he meant that the esc had a nuclear meltdown... as in burned up. A shorted 1000w battery can do that :)
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
crazyjr
crazyjr's Avatar
02.13.2007, 07:23 PM
According to castle, 200* should be the upper limit on both the motors and esc's
Sylvester
Sylvester's Avatar
02.13.2007, 09:17 PM
Ive never gotten my esc over 130F! The melting point of the aluminum is no where NEAR our problems when it comes to heatsinks... near the 200F mark for a while would be enough to "fry things up!" ;)
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
02.14.2007, 02:06 AM
the 100C i said may be a little too hot then.
but i think it was castle where i got that from.
100C is 212F, correct?
losi 8ight-t
xray xt8
glassdoctor
TEAM FUSION
02.14.2007, 10:17 AM
I still think everyone missed the joke in his post... I'm sure he knows 200 won't melt alum. Imagine an esc becoming arc welder... a dead short. That's what he meant I think.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
