03.10.2007, 11:44 PM
But once they fuse together, they'll make a better connection! :)
BoysToys
03.11.2007, 02:07 AM
seth556-- Great choice! XXX-T, Mamba 5700, 3s lipo.
I have the same setup and it rocks! I currently am using a MaxAmps 3s2p 6000mah lipo. I melted a diff gear just like that a couple of weeks back. When you rebuild your diff run it totally locked and put a drop of blule locktite on the nut to keep it from backing off. I love the lipo on the street but swap it out for a 6 cell IB4200 pack in the dirt. I just don't have any fun with the lipo spinning out left and right. After reading about the new MaxAmps 5000 packs I am thinking of getting a 2s version for the dirt. I have clocked mine using GPS at 57mph on the street. Here are a couple of pics of my setup.
jnev
jnev's Avatar
03.11.2007, 03:02 AM
Thats a bad*ss xxx-t you got BoysToys. How do those tires hold up on the street?
BoysToys
03.11.2007, 03:26 AM
Thanks for the compliment. The tires are holding up relatively well seeing how they are run mostly in the street. They have already lasted a lot longer than the poor stockers did.:005: I also have a set of Road Rage 2s. Those are pretty much worthless. I don't get any traction at all with them. In fact, I am thinking of putting them on and doing a burnout in the street with a little bleach.:017: It would be cool to see how much if any smoke I could produce.
seth556
RC-Monster Silicon Carbon
seth556's Avatar
03.11.2007, 08:42 AM
It's just a 4600 motor. It has a perfect mix of speed and torque for me. It's not instantly fast, but still has enough speed to put a smile on my face.
  Send a message via AIM to seth556
Scoob
Scoob's Avatar
03.11.2007, 09:04 AM
I have a 4600 that I run on 3s sometimes. It is very powerful and as much as I would ever want. I geared it very conservatively for low current draw and still have a 40mph truck (gps confirmed) which is enough for me since I never run on the street except to use the gps. I have a 5700 motor also but 5700 with 3s is just too much for anything off road.
bshelton
03.11.2007, 12:58 PM
BoysToys
what spur and pinion do you run? your truck looks sweet. I have those tires and love them with the brushless. before I was running dirthogs and could never get traction.
B
BoysToys
03.11.2007, 04:03 PM
Originally Posted by bshelton
BoysToys
B
bshelton- You have a nic ride yourself. How do you like those RPM wheels. Are they well balanced? I like the look of them and may have to try them out next time I need a set.
I see you are running a Novak 5.5. I had one of those systems with the sintered rotor in my truck for a while then switched it out for the Mamba 5700. With the 3s lipo, I normally run 14/82 with a Robison pinion and a Losi kevlar spur. This gearing comobo keeps my temps down around 180 when running on the street. I can bump it up to 17/82 when running my 6 cell IB4200 pack and still keep the temps under control. Because I am lazy, I normally don't change the gearing when switching from NIMH to Lip. So the truck is usally geared 14/82. I am sure that I will have to adjust this once summer gets here and the ambiant temps begin to rise.
Scoob- I agree with not being able to run the 3s offroad. I tried it a couple of times and could never even get past 1/4 throttle. I like to use a 6 cell packs for offroad duty. To tell the truth, the 5700 with a 6 cell on hard pack is still a handfull to control.
GorillaMaxx360
GorillaMaxx360's Avatar
03.11.2007, 04:20 PM
Originally Posted by glassdoctor
Is that a HV brushless? Oh... looks like it's brushed... what motor?
Bet it's fast huh?
One thing you have got to do is toss those white Tamiya connectors and put some Deans or Andersons on there.... you will probably feel the difference right away. Or you can wait until the white connectors melt together and you are forced to replace them, lol...
It is a brushed stock emaxx controler and motor. I know i need to get the deans on there just never got around to it. the batts are prettyh much dead anyway so i will throw some deans on the new batts.
bshelton
03.12.2007, 10:16 AM
I really like the wheels. they are really well balanced and look so much better than the dish rims. my buddy has the mamba, it is SO much better than the novak. I am going to build an 8th scale buggy with that lease the mamba ecs and hopefully run the new motor coming out this summer. I bought the novak before Castle Creations released the mambamax. wish I would have waited but the truck is fast enough when I am running the 8000 lipo. Just more reason to get the buggy :)
bshelton
03.14.2007, 08:21 PM
how often are you guys having to rebuild the diff? how much diff lube are you using when you rebuild it? It seems like i am having to rebuild it pretty often and I am not sure why. I typically crank it down until it is almost impossible to turn the left tire but the diff still works.
