JIMCRAWLER
JIMCRAWLER's Avatar
07.09.2005, 01:26 PM
Originally posted by GriMM
Yeah.. I got the aluminum idler for it. Now Ive sold the stampede and have been working on a TXT crawler, it has the HV brushless setup in it. But for the life of me i cant find tranny upgrades for this thing.
WOW! Thats alot of power in a crawler!:eek:
MY MGT EATS TMAXX'S CRAPS TNX'S&WIPES IT'S BUTT WITH A SAVAGE!
GriMM
GriMM's Avatar
I wonder if im giving the stock TXT tranny too much power, if i throttle it about 1/4 i can make the entire chassis twist and then roll over backwards...
  Send a message via AIM to GriMM
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
07.09.2005, 01:28 PM
The internal tranny gears are actually mod 1 pitch, which are a bit beefier than the 32 pitch of the pinion/spur. It is unlikely that these are slipping(although anything is possible, I suppose). the instant brakes is likely a radio issue, as you stated.
GriMM
GriMM's Avatar
07.09.2005, 01:29 PM
It definitely is... the good thing about sensored brushless is low speed driveability, it has incredible torque - better then the integy lathe motors i was using before.
Then when you feel like hitting some jumps or ripping it up its got speed too... one of the problems i have though is without a sway bar system the whole rig twists up under heavy throttle and likes to roll
GriMM
GriMM's Avatar
07.09.2005, 01:30 PM
How bad would the temp rise on the HV-maxx motor if I take that gigantic heatsink off?
RC-Monster Mike
Site Owner
So...get a sway bar system(the stock truck comes with sway bars-where are yours?)
GriMM
GriMM's Avatar
07.09.2005, 01:32 PM
I took all of that off to get more articulation - not quite 90 degrees (yet) but it can climb just about anything. I had though about switching out the cantilever system too and moving the mount points to just use shocks, but that would have an even more negative effect towards my roll-overs
RC-Monster Mike
Site Owner
07.09.2005, 01:34 PM
Just disconnect one side of the sway bars when ytou go crawling, and reconnect it when you want to drive fast.
JIMCRAWLER
JIMCRAWLER's Avatar
07.09.2005, 01:55 PM
IMO you have way too much power for crawling. in crawling you need torque but not that much so that your chassis is twistingfrom it. the lnly way you are going to fix thit is to gear way down. in my clod im using 8t pinion. i dont think you will find a happy medium between torque & power using a bl setup.
