Go Back   RC-Monster Forums > Support Forums > Unlimited Engineering
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
05.04.2007, 10:46 AM
Originally Posted by Procharged5.0
Visit the UE website for installation & set-up instructions plu they have set-up sheets for you to mark how you set-up the truck for specific races, etc.
yeah, i found the EXT install instructions... but i don't think it mentioned the washers. i'll check again. thanks!
Eflite Blade 400 heli on 3s
Procharged5.0
Procharged5.0's Avatar
105mm for the FLM Chassis.
ClodMaxx
ClodMaxx's Avatar
05.04.2007, 10:49 AM
sweet. thanks!
Serum
Serum's Avatar
05.04.2007, 11:27 AM
Mike can get you the shafts you need, if you are looking for them.
I used teflon washers on the upper arms (the ones that came as spare with teh UE shocks fit perfect)
ClodMaxx
ClodMaxx's Avatar
05.04.2007, 12:14 PM
i'll ask mike about the cvd's, and that 105mm dogbone too.
so you put the teflon washer in between the 2 bearings, right? the idea is the binding is caused by the bearings rubbing together? i just want to make sure i'm understanding correctly. i've got some teflon washers, and i'll try installing them.
thanks!!! :)
Serum
Serum's Avatar
05.04.2007, 03:09 PM
Lol, no i meant on the hingepin, between the upperarm and the bulk.
You need a spacer between the two bearings to avoid a ruined bearing..
