rampingray
05.06.2007, 09:50 PM
well it seems that i have a bad cell in that one side and now my question is how do i find it?
t/e ext chassis bk warrior 7018 with 9xl motor
05.06.2007, 09:54 PM
If you have a voltmeter, measure each cell. The low one(s) are most likely bad, especially if any are under ~0.9v.
Patrick
Patrick's Avatar
05.07.2007, 04:56 AM
Sometimes even if they're bad they may have a no load voltage that looks good, but as soon as you put a load on it (maybe even just a couple of amps) the voltage will drop right down while the good cells should hold fairly well.
If you test it with a load, it's best to charge the pack first other wise even the good cells may look bad.
05.07.2007, 10:41 AM
Good point Patrick. I would load test each individual cell though...
rampingray
05.07.2007, 08:46 PM
the pack won't even charge past 600mah
Patrick
Patrick's Avatar
05.08.2007, 05:26 AM
Yeah, I meant each cell.
