t-maxxracer32
t-maxxracer32's Avatar
05.07.2007, 06:21 PM
cant wait!!!
also. i figure if something goes wrong with the conversion thenn i will have so many other peoples to base it off of. but i will be ordering everything withtin this month!
GorillaMaxx360
GorillaMaxx360's Avatar
05.07.2007, 07:11 PM
he is converting it to Brushless
t-maxxracer32
05.07.2007, 09:47 PM
who is converting what to bl?
GorillaMaxx360
05.07.2007, 10:21 PM
you, thats is why you would not need a nitro engine. sorry for the confusion
t-maxxracer32
05.07.2007, 10:25 PM
oo haha yep!! cant wait to get it started!!
also do you know if anything is NEEDED to do to the tranny to make it work?
Finnster
KillaHurtz
Finnster's Avatar
05.10.2007, 11:47 AM
If you want motor braking, you have to lock the tranny (into 2nd gear.) See BrianG's thread in the Revo sec.
Instead of going down on the batt count, why don't you go up on the motor turns, ie a 9xl or 10XL (assuming you could get the 6S A123 to fit)?
You can keep the power, but have a cooler running truck w/ longer runtime.
t-maxxracer32
05.12.2007, 10:13 PM
motor braking? what is that? how much slower will a 9xl be compared to an 8xl?
Finnster
KillaHurtz
Finnster's Avatar
05.12.2007, 10:33 PM
You do have plans to stop the truck don't you? :);) I don't see man brakes in there, so you will have to stop w/ the motor. The tranny will freespin due to clutch/oneway bearing if its not locked.
BrianG's Speed calc A 9XL on 6S A123 is faster than a 8XL on 5S A123. I'm not a quark expert, but I believe I've read they will run 6S A123 (22.2V), but 6S lipos (25.2V) are teh trouble spot. I'd personally go with 6S A123 w/ a 10Xl over a 5S A123/ 8XL if you are considering 6S an option. Speeds should be close, but the former will be cooler and give better runtime (but weight is more obviously.)
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.12.2007, 11:12 PM
I agree with with Finnster with that setup, 6sA123 with 9 or 10XL. That will move!
05.12.2007, 11:17 PM
I agree too. We all know the Quark runs just fine at 5s. So:
5s lipo at max charge is 21v (4.2v/cell). The nominal voltage is 18.5v (3.7v/cell).
6s A123 at max charge will be 21.6v (3.6v/cell). The nominal voltage will be 19.8v (3.3v/cell).
zeropointbug
Z-Pinch racer
05.12.2007, 11:43 PM
I would use 17volts (load) for voltage (6s A123) input on Brian's calc for top speed.
t-maxxracer32
05.13.2007, 12:18 AM
hmmm!! thst is cool that i can use 6s a123!! that way i dont have to buy new batts!
t-maxxracer32
05.13.2007, 12:24 AM
so i was just calculating speeds and with the wanderers my max speed i can get is like 35. not too bad but if 35 is my top speed why should i not just get a novak system for it? the reach around 35 right?
which neu motr would i usE? i putsome in and got speeds in the 40s
05.13.2007, 01:12 AM
To gain more speed, you can gear up the Wanderers or the Nues (especially the Neus) easier. The Novaks are more sensitive to gearing from what I've heard (pulls more current than the Novak systems can handle).
05.13.2007, 09:40 AM
That is true, that is true. Havent smoked mine yet but I have blown a batterypack since the motor wanted more juice than it could supply.
