savagehaley14
1988 monte carlo ss
savagehaley14's Avatar
05.22.2007, 09:07 PM
im gonna say no where its only rated at 12 cells maybe if you use fans but im not sure
savagehaley14
1988 monte carlo ss
05.22.2007, 09:08 PM
also how fast will my savage be with the 14 cells and 8xl
savagehaley14
1988 monte carlo ss
05.22.2007, 09:25 PM
does the bk warrior 9920 have a built in ubec(voltage regulator)
05.22.2007, 09:27 PM
Yes, it does, but is linear. Anything over 2s/6cells, use a UBEC. Some will say 3s/9cells is ok, but I wouldn't...
Serum
Serum's Avatar
05.23.2007, 01:32 AM
You are better off with a separate UBEC.
BL_maxx
05.23.2007, 10:06 PM
so then the mamaba isnt a good idea with 14 cells dang it. cuz i have heard that the mamba is superior to the bk or are those false words? man then i can only run twelve cells? well i gues i will see if i can gear down a bit then.
05.23.2007, 10:08 PM
14 cells is starting to push it a little voltage-wise, but should run ok. But, you HAVE to disable the built-in BEC and use a switching BEC instead.
BL_maxx
05.24.2007, 02:09 AM
well i was planning to get a UBEC because of the simplicity of it and less running hardware and i know that i do have to chop the red wire from the esc connecter that goes to the rx? other then that should i put a fan on it? to kep it cooler? well thanx alot brianG yopu have helped me get over this lettle "bump"as you say.
savagehaley14
1988 monte carlo ss
06.05.2007, 10:28 PM
so how fast will the sav x go with the 14 cell and 8xl and are there any good chargers i should think about buying and what batts should i get thanks
BL_maxx
06.06.2007, 12:02 AM
well a charger i would buy and am going to buy is the super brain 989. it charges 1-8 lipo but you need the balancer and 1-25 nimh/nicad cells and it cost 132.99 and has a whole mess more featuresas well like a ten amp power supply to name one. go check it out at towerhobbies.com you can also find other chargers that you might like.
savagehaley14
1988 monte carlo ss
06.05.2007, 10:35 PM
could i run 6s lipo with the 8xl and 9920 bk esc there is a video on the internet of a savage like this and it looks crazy fast
savagehaley14
1988 monte carlo ss
06.07.2007, 10:48 PM
i was thinking the 989 too just wondering if anyones had any experience with anything thanks for the help evryone so far
savagehaley14
1988 monte carlo ss
06.07.2007, 10:50 PM
what mAh rating should i use and does anyone have any battery recomendations
BL_maxx
06.12.2007, 08:40 PM
you can get some ib 4200 7 cells from spec point batteries for 115.95 and there matched and look really nice plus i ordered a set for my maxx and lots of people say they are awsome, but if you ask some one else they might tell you to go lipo with maybe a 5s with 8000mah due to the weight reduction and higher power.
savagehaley14
1988 monte carlo ss
06.14.2007, 03:49 PM
whats the website
