Originally Posted by lydiasdad
Might seem like it's doing ok? HA! I got to get a video camera.
Love to see the video... Please do post if you can.
Originally Posted by AAngel
I suppose it's all a matter of how you want to run. Knowing jhautz (having seen videos of his stuff and how he runs), I think I can safely say that the 1P config isn't going to work very well for him.
AAngle, the goal on this one is a little different than my typical.
In all honesty I'm not that great of a driver on the track and the point of going to a smaller motor was to take it down a notch in power allowing me to have a little more control. Now I cant say that the 1930 is really less power than the 1512 that was in it before which is why I'm looking to tame it out by going to a lower voltage. Like I said before its still a little to much for me on 4s and 3s isnt quite enough. Which is why Im thinking the 4s A123 will be like a 3.5s lipo. Right about where I want it.
I could build a 4s2p pack from the reamining 8 cells I was jut thinking that with the smaller motor and a 1p pack I could get a nice lightweigh setup to draw less amps.
I was skeptical that A123 would be able to deliver the power that it states in the specs without stressing the cell severly which is why I originally asked this question. It sounds like some of you have seen what I was suspecting. The cells can do it, but its less than optimal. Others seem to be having sucess. If the cells deliver what they are speced at I was thinking that they would be capable of doing what I want, but just barely.
The cells according to the spec sheet are rated for 70A constant and 120A peaks. With the 4s Lipos setup I was running I saw around 80A peaks at 14.8V = 1184Watts and I averaged only around 13.5Amps over the entire run. So based on this I'm calculating:
Power with 4s Lipo:
89A * 14.8V = 1317 Watts peak
and
13.5A * 14.8V = 200 Watts Average
and
the 4350mah pack gives about a 22 minute run time.
To generate the same power using 4s A123 I would need:
1317Watts / 13.2V = 99 Amps peak
and
200W / 13.2V = 15.15 Amps avarage
and
the 2300mah pack should give me around 9.1 munite run time if the above assumptions are true.
Now according to the spec sheet the a123 cells rated at 70A constant and 120 Peak should be able to do this. And in reality I actually want to generate a little less power than I did with the 4s lipos. I know that real world doesnt translate directly like my example here, but it should be at least a reasonable estimate.
I think what I just calculated is correct... If I'm missing something can someone let me know what I'm missing.
I guess there is only one way for me to find out... I'll use the 8 cells and build two 4s1p packs. Run it with both the 4s1p and then with both packs in a 4s2p configuration and see what I get on the eagletree and more importantly how the whole setup "feels".
