Serum
Serum's Avatar
06.03.2007, 02:48 AM
So far i haven't heard about a smoked 40.160 yet, they seem to be bombproof, from what i've heard.
Only point is they are the size of spain. :p
But it is one heck of a controller!
captain harlock
RC-Monster Captain
captain harlock's Avatar
06.03.2007, 08:25 AM
I noticed that the most important procedures one should take with any controller to insure a safe and smooth operation, is to make the wires super short( I even thought about connecting the controller directly to the motor with no wires at all!!!) Hard wiring without the usage of connectors between the motor and esc. When using a large pinion gear, it will drain loads of amps out of the controller and will greatly heat the wires and motor. You should use high quality connectors with a great heat resistance capability( the deans are good, but the 6mm sized schulze connectors or BK's 5.5mm ones are much better). Some controllers come with 13-14GA wires, for extra safety( espicially in Monster Trucks and buggies), replace them with 12GA wires( Dean's Noodle wires, for example). A cooling fan on the motor and controller is a good topping, but shorting down the wires is more ipmortant.
I believe most of you know this, but thought about refreshing your minds.
I made those precautions on my 18.149 schulze controller and it did not break a sweat under hard acceleration. Just DON'T use brakes a lot.
Nice to meet you!
lutach
lutach's Avatar
06.03.2007, 08:31 AM
AAngel,
I bought the controller about a year or so ago. My point exactly. It is expensive and I also heard that Schulze is not the best with customer service.
lutach
lutach's Avatar
06.03.2007, 08:42 AM
Serum,
The size is not a big issue on the truck. I'm just afraid the controller might go up in smoke and I hate to loose a controller like that.
Captain,
The wires on the CC HV110 are 10GA and they are shorter than all my other controller's wires. I also haven't had the chance to buy the 5.5 or 6mm connectors, but I'll be changing all the connectors. The HV110 ran fine 3 days ago when I did a short test, but yesterday as soon as I gave a little throttle it started smoking. The pinion in the truck right now is 22T and the spur is 51T and the diffs are 3.3 from the buggy. The truck also weighs over 10lbs so I might be overloading things a bit.
lutach
lutach's Avatar
06.03.2007, 08:54 AM
Mine was on sensitive as well. Also, I had it in soft start to protect fragile gear boxes, the cut off at 24 volts.
Originally Posted by Eccentric
What did you have your "current limiting" setting at? I have mine on the Option 2 (sensitive), though now I might go the the Option 1 (very sensitive).
The owners manual says that the warranty doesn't cover over current. So he might be on his own here.
You can get the sensor that will got up to 300amps and 50v for the Eagle Tree but it's $130.
AAngel
06.03.2007, 12:28 PM
I tried the 6mm connectors and they are nice and wide, but short. They also have a lot of contact area, but they are kind of thin. I tried out the 5.5mm conncectors and they have a more substantial feel to them. I'm using the 5.5mm connectors now.
Eccentric
06.03.2007, 01:48 PM
I have mine on the softstart and still broke gears and driveshafts. I also have it on softcut. I don't have an Eagle Tree to make more accurate assumptions so my settings are just guesses. I thought that throttling down rather then cutting power off wouldn't create as high a spike when the ESC went back to normal. This tread is making me think I need to invest in an Eagle Tree system.
lutach
lutach's Avatar
06.03.2007, 02:13 PM
I was browsing through Neu Motor's website and saw that they mention 140+burst out of the HV110. The yalso show a 180AMP controller with 300AMP bursts.
lutach
lutach's Avatar
06.03.2007, 03:26 PM
I'll give this bad boy a try. Lets hope it doesn't smoke.
http://www.rcpics.net/view_single.php?medid=85050
http://www.rcpics.net/view_single.php?medid=85051
http://www.rcpics.net/view_single.php?medid=85052
AAngel
06.03.2007, 04:13 PM
That Schulze is huge, but it's purdy. I think I'd make room to be able to run that thing.
lutach
lutach's Avatar
06.03.2007, 05:06 PM
Everything is hooked up and tomorrow I'll try it out. I did a quick test and everything is running, but tomorrow I will see how good this thing is.
06.03.2007, 05:09 PM
From what I've heard, those Schulze ESCs run just about anything and run smooth.... until they burst into flames. I wonder if it would help if they added heatsinks?
How is the programming on those ESCs? I doubt they are as programmable as the MM - I assume they have about as many options as a Quark?
lutach
lutach's Avatar
06.03.2007, 05:14 PM
Man I hope this thing doesn't burn. Programming is very easy through some DIP switches and they have something called ISP (Intelligent Self Program) something like that. I also think you can program it using your radio like most ESC.
06.03.2007, 05:21 PM
Well, I wish you the best of luck. Some people run theirs forever with no issues, so as long as you aren't pushing the V or A ratings, I think you should be fine.
lutach
lutach's Avatar
06.03.2007, 06:46 PM
All I want is to get the truck to go 80 or maybe 100MPH. After that I'll cool down a bit.
